Dehumidifiers Logo
R
Robin Posted on Jun 13, 2023
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Zip tie stuck inside Danby dehumidifier
I was trying to fix my leak with a zip tie as suggested, and poked it too high and lost it. I think it's fully inside. Unsafe? Suggestions?
ADMIN Andrew
Level 3:
Top Expert:
  • Danby Master 73,781 Answers
  • Posted on Jun 14, 2023
ADMIN Andrew
Danby Master
Level 3:
Top Expert:
Answers
73781
Questions
Helped
6295750
Points
431340
Not a problem, they are full of plastic.
Water is leaking out .At first i thought the tank had developed a leak but no, somehow the water is not getting into the tank .Is there something i need to clean? It was working great until this started...
More than likely, the tubing the drains the water to the water collection bucket is clogged. To solve this problem, turn the unit OFF and unplug it.
Remove the water collection bucket and look up inside the bucket holder cavity. You will see either a drain hole or small tubing that drains the water into the bucket. Using an appropriately sized, 18" long, plastic Zip Tie, carefully insert the tip of Zip Tie into the hole or tubing. Continue to push it in until you reach a bend in the tubing. You will need to gingerly work the Zip Tie past this bend, until it either bottoms out or you run out of usable Zip Tie. Then slowly pull the Zip Tie back out while rotating (twisting) it. This will breakup any clogs. As you reach the inserted end of the Zip Tie, be prepared, as some water may follow. Reinstall the bucket, plug the unit in and turn the Master ON/OFF Switch to ON. Set the humidity extraction level to 35% or Maximum if you have a manually controlled unit. Allow the unit to run, while you monitor it for any leakage.
NOTE: If you don't have a Zip Tie, you may use something similar ( i.e.a long pipe cleaner), but NO wire coat hangers.
I hope this helped you to solve the problem and thanks for choosing FixYa.
1helpful
My dehumidifier is leaking from the bottom. Was working fine. Bucket is only collecting about an inch of water. any suggestions
The problem is due to clogged tubing inside the unit. To solve the problem, do the following:
I hope I was able to help you solve the problem. Thanks for choosing FixYa.
2helpful
I have had my Danby ddr606 unit for 4 years in my basement. It has been running with a hose connected to it that allows the water to drain in the sump pump so I do not have to empty the "bucket"...
Yes. Either the hose is clogged or the hose connection and it's tubing is clogged. When that happens, water is automatically diverted to the bucket. The hose is easy to check for a blockage. Simply remove it and either blow thru it or look thru it for daylight.
To clear the hose connection and tubing. Use an 18" long appropriately sized Zip Tie. Insert the end of the Zip Tie into the hose connection and carefully work it in. You will reach a bend in the tubing that you need to gingerly work the Zip Tie past. Continue to insert it until the Zip Tie bottoms out or you run out of usable Zip Tie. The slowly pill the Zip Tie back out while rotating (twisting) it. This will dislodge any clogs. As you reach the tip of the Zip Tie, be prepared as some water may follow. Hook the hose back up, plug the unit in and turn it On. Set the humidity extraction level at 35%. Monitor the end of the hose for water flow, after about 15 - 20 minutes. If water doesn't start to flow, turn the unit OFF and repeat the above procedure. Also, remove the air intake filter and clean it if necessary.
Hope this helped to solve the problem and thanks for choosing FixYa.
Leaking dehumidifier When hose is attached it still drains into cotainer
The hose of the hose connector on the unit may be clogged. When this happens, water is diverted to the bucket.
Turn the unit OFF & unplug it. Disconnect the hose from the unit and check the hose for a clog. If none is found, the clog is in the hose connection tubing, inside the dehumidifier. Using an 18" long plastic Zip Tire or something similar (NO wire coat hangers, though). Insert the tip of the Zip Tie into the hole and continue to push it in, until you reach a bend in the tubing. Gingerly work it past this bend, until the Zip Tie bottoms out or you run out of usable Zip Tie. Then pull the Zip Tie out slowly while rotating (twisting) it. This will dislodge any clogs. As you reach the inserted end of the Zip Tie be prepared, as some water may follow. Reattach the hose, plug the unit in and turn it ON. Set the humidity extraction level at 35% and monitor the hose for water running out. Be sure the hose is no longer than 5 feet and is sloped downward to the floor drain. As drainage relies on gravity.
I hope this helps you to troubleshoot and solve the problem. Thanks for choosing FixYa.
I have a hose hooked up in the back to continually drain water but it isn't working. I have to keep emptying the water. How do I get it to work? And if I take out the plug water leaks everywhere.
The problem you're facing is either a clog in the drain hose or a clog in the hose connector's tubing.
The drain hose is an easy one to insect and clean, if necessary. For the hose connector tubing, you need to do the following.
Turn the unit OFF & Unplug it.
Using an appropriately sized, 18" long, plastic Zip Tie, carefully insert the tip of Zip Tie into the hole or tubing. Continue to push it in until you reach a bend in the tubing. You will need to gingerly work the Zip Tie past this bend, until it either bottoms out or you run out of usable Zip Tie. Then slowly pull the Zip Tie back out while rotating (twisting) it. This will breakup any clogs. As you reach the inserted end of the Zip Tie, be prepared, as some water may follow.Reconnect the drain hose, plug the unit in and turn the Master ON/OFF Switch to ON. Set the humidity extraction level to 35% or Maximum if you have a manually controlled unit. Allow the unit to run, while you monitor it for drainage thru the hose.
Hope this helped you solve the problem. P;ease let me know. Thanks.
3helpful
I have an LG 45Ely6, the tank was reinstalled properly but it continues to leak. Can you help?
More than likely, the water drain tubing inside the unit is clogged& the water is not going into the bucket as it should. To solve this, do the following.
1. Turn the Master ON/OFF to OFF & Unplug the unit.
2. Remove the bucket and look up inside the bucket holder. You will see a tube or a hole that drains
3. Using an 18" long plastic Zip Tie or something similar (NO wire coat hangers though) that is
appropriately sized to fit into the hole or tubing. Carefully insert the Zip Tie, until you reach a
bend in the tubing. You will need to gingerly work it past this bend, until the Zip Tie either
bottoms out or you run out of usable Zip Tie. While rotating (twisting) the Zip Tie, slowly remove it.
As you reach the inserted end of the Zip Tie, be prepared for some water to follow.
Hope this helped you troubleshoot and solve the problem. Please let me know. Thanks.
The humidifier is working but the water is going inside the appliance and not in the bucket?
The drain hole or tubing that goes into the bucket is clogged. To solve this, you will 18" long plastic Zip Tie or something similar (NO Wire Coat Hangers) that is appropriately sized to fit into the hole. To access this drain hole or tubing, remove the bucket and look in above where the bucket came out. You will see a hole or plastic tubing. Insert the Zip Tie carefully and work it in until you reach a bend in the tubing. You must gingerly work it past this bend and continue pushing it in, until it either bottoms out or your run out of workable Zip Tie. Then while rotating it, slowly pull it out and be prepared for some water to follow.
That should solve the problem. Please let me know. Thanks.
1helpful
Unit not discharging through garden hose. Just cleaned unit inside and out. Works great, BUT, only discharges into its container. What am I missing. Cleaned all hoses - no blockages. What should I be...
The blockage is not in the hose, it's inside the hose connection drain tube. To clear this clog, you will need an 18" long plastic Zip Tie, sized to fit into the drain hole. You can use something similar, but NO wire coat hangers. Carefully thread the Zip Tie into the hole and continue to firmly, yet gently work it in, until it reaches a bend in the tubing. You will need to gingerly work it past this bend, until it either bottoms out or you run out of Zip Tie. Then slowly pull it back out while rotating it. This will help remove the clog. Once you have pulled it almost all the way out, be prepared for some water to follow.
That should solve the problem for you. Please let me know. Thanks.
2helpful
My danby dehumidifier is suddenly leaking from the bottom .. I have a hose that runs down my drain in the basement .. It was all working great until a month ago .. now there is water leaking from...
Turn the unit OFF and unplug it. Disconnect the hose from the outlet on the unit. Using a plastic 18" Zip Tie, that will fit easily into the drain outlet, carefully insert the Zip Tie and insert it as far as you can. You will reach a bend in the tubing, so gingerly work it past that bend. Once the Zip Tie has reached as far as it will allow, start pulling it slowly back out, while rotating it. This will dislodge any clogs, so be ready for water to follow. It also would be wise, to clean out the tube or hole that drains into the bucket, as it may also have a clog in it.
Hope this helps you to solve the problem, Joanne.
9helpful
My Danby dehumidifier leaks out of the bottom. Water not draining into the tank but around the tank therefore out of the bottom between the tank and the dehumidier itself
The drain tube or hole that drains into the bucket is probably clogged.
Turn the unit OFF and remove the bucket. Look in the cavity where the bucket was removed for a drain tube or drain hole. Using an 18" long plastic Zip Tie or something similar (No wire coat hangers) , that's appropriately sized to fit in the hole. Carefully feed the ZIP Tie into the hole or tube and thread it as far as you can. At some point the drain will curve, but you have to carefully get past this point. Once the Zip Tie has reached as far as it can, slowly pull it out while rotating it. This will loosen the clog. Once you have it half way out, be prepared for water to follow. This method should solve the problem.
Top Danby Dehumidifiers Experts
ADMIN Andrew
ADMIN Andrew
Don A
Don A
Anonymous
Are you a Danby Dehumidifier Expert? Answer questions, earn points and help others
