Danby DDR451 Dehumidifier Logo
Anonymous Posted on Dec 30, 2009
E1 CODE ERROR
My DANBY Dehumidifier model DDR4588EE has been working ok until itshowed a E1 error code and since then it does not work properly. Anyideas please?
Anonymous
Level 2:
Scholar:
  • Expert 117 Answers
  • Posted on Jan 05, 2010
Anonymous
Expert
Level 2:
Scholar:
Answers
117
Questions
0
Helped
67067
Points
213
E1 code for the primary humidity sensor behind right side grill. Unit MUST be unplugged from outlet. Take right side grill out, unplug sensor from wire socket and plug back. If no help, you need new sensor.
  • Anonymous May 26, 2013
    This so far has worked for me...... I unplugged the sensor plugged it back in and the error went away and the unit seems to be operating properly.
E-1 error
The E1 error code indicates that the air intake filter needs to be removed and cleaned. Be sure to turn the unit OFF & unplug it before removing the filter. Never operate the unit without the filter in place. Doing so, could damage the unit.
Hope this helped you and thanks for choosing FixYa.
2helpful
What is the proper setting for Danby R410A?
R410A is refrigerant gas. I think you wanted to know, what humidity extraction level the controls should be set on. If it is really hot and humid in your area, set the humidity extraction level between 35 & 40%. If you have a mechanical control, turn the knob to Maximum.
Hope this helped you, Bradleyjo. Thanks for choosing FixYa.
I need to replace the water tank for my Danby model DDR4588EE. Any suggestions where I can get it?
Contact Danby at 800-496-6049 for parts not covered under warranty.
Hope this helps you and thanks for choosing FixYa.
Hi my Danby DDR4588EE Dehumidifier's buttons aren't working
Hi! I'm assuming that the unit is plugged in and the outlet the unit is plugged into is working (if not, is there a tripped circuit breaker, in your home's circuit breaker panel?). Also, that you have turned ON The Master ON/OFF Switch and the Water Collection Bucket is installed properly and the Float Valve inside the bucket is in the Down position
If you answered NO to any of the above, turn the the Master ON/OFF Switch to OFF and unplug the unit, before checking those things first. Because, 9 times out of 10, one of thee above is the culprit.
Hope this helps you troubleshoot and solve the problem. Please let me know. Thanks.
Frosting up in front after it been on for awhile
Here is a tip that I wrote that will help you understand why and what you can do with a dehumidifier that ices up.
Dehumidifier is Freezing up and not working
heatman101
5helpful
I need a manual for Danby dehumidifier DDR4588EE
You can get the manual on the link below.
http://www.danby.ca/cms/uploads/products/en_manual/DDR3008_EOM.pdf
Good Luck and please rate 4 thumbs up for the free answer
6helpful
My DANBY Dehumidifier model DDR4588EE has been working ok until it showed a E1 error code and since then it does not work properly. Any ideas please?
126helpful
7answers
What Do P1 and P2 Error Codes Mean on My Dehumidifier?
Danby's Consumer Help Line (1-800-263-2629) is always busy. So, I called their General number: 419-425-8627. The receptionist transferred my call to their Service dept. My call was answered in 2 minutes.
The Service Rep. described the following code for my dehumidifier model (DDR657EE):
P1 = Defrosting: the unit will go into Defrost mode periodically to ensure that the parts are working at the right operating temperature. It should be in Defrost (P1) mode for only a brief period of time. If the unit is in Defrost (P1) mode continuously for a couple of hours (or more), then you should call Danby Service for further assistance.
He had no documentation of a P2 code for my model.
He also described other General Codes (applicable to most Dehumidifier/Humidifier models):
E1 = Not enough water
E2 = Not draining
E3 = Water temperature too cool
E4 = Overflow Switch activated
E6 / E7 = Problem with Temperature Sensor
I hope that helps.
Top Danby Dehumidifiers Experts
ADMIN Andrew
ADMIN Andrew
Don A
Don A
Anonymous
Are you a Danby Dehumidifier Expert? Answer questions, earn points and help others
