Danby DDR2509EE Dehumidifier Logo
Posted on Jul 14, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a hose hooked up in the back to continually drain water but it isn't working. I have to keep emptying the water. How do I get it to work? And if I take out the plug water leaks everywhere.
Anonymous
Level 3:
Brigadier General:
  • Master 4,736 Answers
  • Posted on Jul 14, 2011
Anonymous
Master
Level 3:
Brigadier General:
Answers
4736
Questions
0
Helped
2144011
Points
14644
The problem you're facing is either a clog in the drain hose or a clog in the hose connector's tubing.
The drain hose is an easy one to insect and clean, if necessary. For the hose connector tubing, you need to do the following.
Turn the unit OFF & Unplug it.
Using an appropriately sized, 18" long, plastic Zip Tie, carefully insert the tip of Zip Tie into the hole or tubing. Continue to push it in until you reach a bend in the tubing. You will need to gingerly work the Zip Tie past this bend, until it either bottoms out or you run out of usable Zip Tie. Then slowly pull the Zip Tie back out while rotating (twisting) it. This will breakup any clogs. As you reach the inserted end of the Zip Tie, be prepared, as some water may follow.Reconnect the drain hose, plug the unit in and turn the Master ON/OFF Switch to ON. Set the humidity extraction level to 35% or Maximum if you have a manually controlled unit. Allow the unit to run, while you monitor it for drainage thru the hose.
NOTE: If you don't have a Zip Tie, you may use something similar ( i.e.a long pipe cleaner), but NO wire coat hangers
Hope this helped you solve the problem. P;ease let me know. Thanks.
Top Danby Dehumidifiers Experts
ADMIN Andrew
ADMIN Andrew
Don A
Don A
Anonymous
Are you a Danby Dehumidifier Expert? Answer questions, earn points and help others
