Computers & Internet Logo
N
Norma DesRoches Posted on Aug 25, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I remove a document from queue? - Acer Computers & Internet
Nikhow
Level 3:
Dedicated:
Visited the website for 20 consecutive days.
  • Master 436 Answers
  • Posted on Aug 25, 2014
Nikhow
Master
Level 3:
Dedicated:
Answers
436
Questions
0
Helped
133540
Points
1221
Go to start orb.
Type in the search box 'Print jobs' .or 'Print Management' Go from therr.
1helpful
How to remove need for printer queue
no need to remove the printer queue as it will select the next job automatically
so if you have set it printing something and the want to print another document , it will finish the first then start the second
the queue is need as it stops the printer printer printing any page from any where at any time so removing the queue will cause you lots of pain
Assuming Windows, open the queue. Win 7 has it in the "Devices and Printers" screens. Click on the printer, open the queue, then select the document you want to remove, right click, and cancel printing.
I have one (1) queue in my printer, x1185, how do I remove it?
Highlight the document by left clicking it once
then from the dropdown list in the queue box select DOCUMENT then cancel
Brand new printer not working. I think document get stuck in queue and will not print.
if your saying they are stuck in queue here is a way to remove them from queue.
At bottom - right of your toolbar (near the windows clock at the bottom) you will see a small printer icon there.
Right click it and choose open all printers.
There you will see all the documents that are queued. Just cancel and delete all the files.
Hope i help. Please give me feedback about my solution thanks.
When I click print the document goes into queue then when I troubleshoot it says the printer wont print because a document is in queue. When I clear all documents it says "printer ready" but then it says...
Remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and connect the Printer to be detected and installed. Check printer properties to see the ink levels.
Use head cleaning before a test is taken .
1helpful
I can't delete a document in the queue for
remove usb cable from the printer then try to cancel it then after switch off your printer then after trying to cancel if problem occurs then u have remover your printer driver and reinstall it
Printer keeps printing page after page of meaningless symbols.
Did you have document in queue?If you have delete all documents in queue and restart the computer.Then restart printer.Wait to document in queue deleting.If you haven't documents in queue reinstall the drivers.First delete old, reset computer and install new.
1helpful
Document goes to the print queue, then errors
To start with You check the data cable is properly connected to your printer than you open the printer dialogue box and remove the documents pending in the queue and retstart the computer and before giving the print command select the printer that you are going to use(if more printers are connected to the computer).if all this does not work i suggest you to reinstall the printer after uninstalling it
I want to print new page of printing printer keeps churning out prvious printing instrctions i am 78yrs old still learning
What you need to do is clear out the printing "QUEUE".
Clearing the Print Queue in Windows
The printer is one of the slowest devices in a computer system. If you had to wait for it to print your document before you could resume writing, you would quickly go back to using a typewriter. To eliminate the delay, Windows reserves a portion of memory for something called a “print queue” (or spooler). The queue works on a first-in first-out basis. You can continue to use the computer and send jobs to the spooler as it feeds a steady stream of data to the printer.
Print queues are nice, except when something happens in the printer to cause it to stop functioning. Sometimes it is just a paper jam and sometimes it is a bit more serious. If you need to cancel the jobs in the print queue, you can simply double-click the printer icon (in the system tray down by the clock) and open the print queue. Depending upon the length of your document and how many documents are waiting to print, the printer icon may appear briefly or for a sustained period. (Note: This would be a good time to remove the paper from the printer before continuing.) If the icon is not there, you can manually open the queue.
Open the Print Queue
  • Windows 98 - click Start, Settings, Printers
  • Windows XP - click Start, Printers and Faxes
    or click Start, Control Panel, Printers and Faxes
  • Windows Vista - Start, Control Panel, Hardware and Sound, Printers
Double-click to open the appropriate printer's queue. The Print dialog box will open. Here you will see a list of all of the jobs waiting to print, along with the status of each job. The first print job is at the top of the list.
To cancel a document in the list, right-click it and select Cancel Printing. Most often, it is better to cancel all of the jobs and then resend the documents to the printer.
Cancel All Documents
  • Windows 98 - click Printer on the menu, select “Purge Print Documents”
  • Windows XP - click Printer on the menu, select “Cancel All Documents”
  • Windows Vista - click Printer on the menu, select “Cancel All Documents”
Please note that you must have Administrative rights in Windows XP and Vista to cancel print jobs. If you are the only user, you automatically have administrative rights. If you are on a multi-user computer, you must be an administrator. If are on a network and get a message saying that you do not have Administrative rights, find someone who does.
Under normal circumstances, printing documents are cancelled and will disappear from the queue. If one or more do not disappear, shutdown the computer and restart. When shutting down, you may get a message warning you that your print jobs will be lost if you continue. Tell Windows to shutdown anyway. When you restart, Windows may tell you that you have print jobs waiting. Tell Windows to delete them.
Before you resume work, open the Print Queue from the Start menu. You should find the queue empty. If you are using Windows XP or Windows Vista and the queue is not empty, you will be unable to print. Before trashing your computer, you can try to clear the queue using a secret Windows command.
Click Start, Run, and type “Net Stop Spooler” (without the quotes). Then press Enter. Shutdown the computer and restart. The print jobs should be removed. If they are not, shut down the computer again, take a deep breath, and then go for a long walk. The queue should be clear when you return. Note that you must restart the computer for your printers to resume normal operation.
This should solve your problem, Let me know how it works for you..
~~Jastababe~~
Printer won't print
I disconnected the USB cable from the printer and computer. I waited 6 seconds and then reconnected them. The document disappeared from the queue and I was able to print.
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
Sudeep Chatterjee
Sudeep Chatterjee
