w
william douglas Posted on Aug 30, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to remove need for printer queue - PRINTER Office Equipment & Supplies
Bill Boyd
Level 3:
Top Expert:
  • PRINTER Master 53,816 Answers
  • Posted on Aug 31, 2017
Bill Boyd
PRINTER Master
Level 3:
Top Expert:
Answers
53816
Questions
7
Helped
12331554
Points
172813
No need to remove the printer queue as it will select the next job automatically
so if you have set it printing something and the want to print another document , it will finish the first then start the second
the queue is need as it stops the printer printer printing any page from any where at any time so removing the queue will cause you lots of pain
How do I delete a print job?
turn off the printer and remove power to the printer. Job will be stored in printers memory. Go to p.c you printed from and check printer queue see if job is in printer queue on p.c as well and then delete from queue. If it does not delete from the queue go to if windows p.c the services under control panel and stop and restart the spooler service.if print job is stuck in the printer queue.
How do I remove a document from queue
Assuming Windows, open the queue. Win 7 has it in the "Devices and Printers" screens. Click on the printer, open the queue, then select the document you want to remove, right click, and cancel printing.
Need to remove queue error from Dell PC & Epson RX 500 printer
I would uninstall all versions of the printer and reboot the PC. Check that no remnants of the printer software are left on the PC and then re-install the printer. Use the CD that came with the printer when installing.
Need to clear out my primnter queue then uninstall & reinstaal the driver and printer
Press the windows key + r to get to the run prompt. Type services.msc. Scroll down to Print Spooler. Right click and select stop. Go to C:\Windows\System32\spool\PRINTERS and delete all files. Go back to the Print Spooler service and start the service. At this point your print queue will be empty. You should be able to go to control panel and (XP Add Remove Programs or Vista 7 Programs and Features) and remove the driver from there. I'm assuming this is your printer: http://www.dell.com/support/drivers/us/en/555/Product/dell-926. If so, you can download the newest driver from there.
2answers
Our printer has 11 unprinted requests in its memory. we need to remove them to get the printer started.
Assuming you're running Windows...first turn off your printer and unplug it. Then, in the Windows printer queue, click on Printer and then on Cancel All Documents.
Then restart Windows. When it comes back up, the printer queue should be empty. Then plug your printer back in and turn it on.
Hope that's helpful.
1helpful
How to i clear the queue with jobs waiting to print when the printer says printing but is not printing
Try pressing cancel on the printer first. Then, open the print queue by opening the printers folder, and double-clicking the printer icon for your printer. Try to select the jobs there and cancel them. If that doesn't work, turn off the printer, and wait for the title bar of the print queue to say "use printer offline". If it doesn't change on the title bar of the queue, then select "use printer offline" from the file menu of the print queue. Then try to delete the print job. If this still doesn't work, leave the printer off and reboot the computer, then try to delete the print job again if it is still in the queue. If none of these work, remove and then reinstall the printer as a last resort.
When I click print the document goes into queue then when I troubleshoot it says the printer wont print because a document is in queue. When I clear all documents it says "printer ready" but then it says...
Remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and connect the Printer to be detected and installed. Check printer properties to see the ink levels.
Use head cleaning before a test is taken .
1helpful
I finally cleared a paper jam, and now my printer is trying to reprint all the documents I sent to print while there was a jam. I do not want these to print since it will waste a ton of paper and ink. How...
There should be a little print queue icon down by the clock.  Double-click on this to open the print queue program.  From there you can remove jobs from the queue.  NOTE:  It can take a minute or two for jobs to remove themselves.  It's not instant.
Please rate me if you found this helpful.  Thanks.
1helpful
Can't get printer to cancel print
If this is a Windows pc - turn off the printer, right click the printer icon in the lower right taskbar, choose the option to show your printer queue, right click the print job and choose cancel or delete. After the job is removed from the queue you may restart the printer.
Note: you can access the print queue from the printers folder also by simply opening the printer which you wish to control...
I want to print new page of printing printer keeps churning out prvious printing instrctions i am 78yrs old still learning
What you need to do is clear out the printing "QUEUE".
Clearing the Print Queue in Windows
The printer is one of the slowest devices in a computer system. If you had to wait for it to print your document before you could resume writing, you would quickly go back to using a typewriter. To eliminate the delay, Windows reserves a portion of memory for something called a “print queue” (or spooler). The queue works on a first-in first-out basis. You can continue to use the computer and send jobs to the spooler as it feeds a steady stream of data to the printer.
Print queues are nice, except when something happens in the printer to cause it to stop functioning. Sometimes it is just a paper jam and sometimes it is a bit more serious. If you need to cancel the jobs in the print queue, you can simply double-click the printer icon (in the system tray down by the clock) and open the print queue. Depending upon the length of your document and how many documents are waiting to print, the printer icon may appear briefly or for a sustained period. (Note: This would be a good time to remove the paper from the printer before continuing.) If the icon is not there, you can manually open the queue.
Open the Print Queue
  • Windows 98 - click Start, Settings, Printers
  • Windows XP - click Start, Printers and Faxes
    or click Start, Control Panel, Printers and Faxes
  • Windows Vista - Start, Control Panel, Hardware and Sound, Printers
Double-click to open the appropriate printer's queue. The Print dialog box will open. Here you will see a list of all of the jobs waiting to print, along with the status of each job. The first print job is at the top of the list.
To cancel a document in the list, right-click it and select Cancel Printing. Most often, it is better to cancel all of the jobs and then resend the documents to the printer.
  • Windows 98 - click Printer on the menu, select “Purge Print Documents”
  • Windows XP - click Printer on the menu, select “Cancel All Documents”
  • Windows Vista - click Printer on the menu, select “Cancel All Documents”
Please note that you must have Administrative rights in Windows XP and Vista to cancel print jobs. If you are the only user, you automatically have administrative rights. If you are on a multi-user computer, you must be an administrator. If are on a network and get a message saying that you do not have Administrative rights, find someone who does.
Under normal circumstances, printing documents are cancelled and will disappear from the queue. If one or more do not disappear, shutdown the computer and restart. When shutting down, you may get a message warning you that your print jobs will be lost if you continue. Tell Windows to shutdown anyway. When you restart, Windows may tell you that you have print jobs waiting. Tell Windows to delete them.
Before you resume work, open the Print Queue from the Start menu. You should find the queue empty. If you are using Windows XP or Windows Vista and the queue is not empty, you will be unable to print. Before trashing your computer, you can try to clear the queue using a secret Windows command.
Click Start, Run, and type “Net Stop Spooler” (without the quotes). Then press Enter. Shutdown the computer and restart. The print jobs should be removed. If they are not, shut down the computer again, take a deep breath, and then go for a long walk. The queue should be clear when you return. Note that you must restart the computer for your printers to resume normal operation.
This should solve your problem, Let me know how it works for you..
~~Jastababe~~
Top PRINTER Office Equipment & Supplies Experts
vince
Are you a PRINTER Office Equipment and Supply Expert? Answer questions, earn points and help others
