Ricoh Aficio 1035 Copier Logo
Anonymous Posted on Jan 18, 2011
Sc322 - Ricoh Aficio 1035 Copier
Anonymous
Level 1:
New Friend:
  • Contributor 22 Answers
  • Posted on Jan 18, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
22
Questions
Helped
15418
Points
55
Sounds like the laser unit has failed!
SC322 - 1st laser synchronization error - • The 1st laser synchronization signal cannot be detected by the main scan synchronization detector board even if the laser diodes are activated.
Poss causes:
  • Poor cable connection between the laser synchronization detector board and the LD unit.
  • Laser synchronization detector board out of position and angle of reflection not correct
  • Laser synchronization detector board defective
  • LD unit defective
If switching the machine off/on doesn't cure it you probably need a new laser unit. Has it been extra noisy before it failed? Whining/screeching/rattling?
  • do a laser sync initialization for the 400 and 600 dpi, enter service mode... yellow 1 0 7 and +- 5 seconds on the stop (orange button) go to copy sp, go to drum and there you will find LD initialization...
How do i clear code sc322 on nashua aficio 2016
THIS VIDEO SHOW HOW FIX IT
https://youtu.be/-DGnULMHtD4
Lanier LD118d showing a error sc322, how to fix
sc322 is an error with the copier's laser unit. You can pull the laser unit out and clean it up if there is toner on or in it, but more than likely either the polygon mirror motor or the laser unit as a whole assembly should be replaced.
2helpful
After sc326-00 my copieur ricoh aficio 350 put on his screen sc322-00 and not work, how cold i resolve this problem
Laser Synchronization Error(1 & 2)(sc322 & sc326)
· Laser synchronization detector board out of position
· Laser synchronization detector board defective
Also check if any cables are loose and also if the laser unit is dirty.-Clean it.
3helpful
Functional Problem SC322
Polygon mirror motor is bad. Sometimes you can put a drop of oil on the shaft, but at best is a temporary fix. You'll end up having to replace it. Good luck
SC322 on Savin 4035
Laser synchronization error. It could be just toner on the LD unit. Try cleaning and doing the Pitch adjustment. If that doesn't work , then either the unit itself is bad, or the Sync. Detector board.
***This will obviously require a tech.
8helpful
3answers
I need solution to aficio 200 error code sc322
sc322 is a Laser synchronization error:
Means that the laser synchronization signal cannot be detected by the main scan detector board.
Possible causes:
Poor connection of the interface harness which connects the laser synchronization detector board and the BiCU board.
Laser synchronization detector board out of position or is defective.
BiCU board is defective.
Unfortunately,unit needs service.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
1helpful
2answers
Lanier 5645 SC322 Error
It's most likely your Laser diode (LD unit). You're going to require a tech...see the posts the following link for the same problem. It's for a Ricoh model, but your machine actually is a Ricoh Machine (Ricoh owns Lanier), and is virtually identical to this one -just a generation older.
http://www.fixya.com/support/t1936988-sc_326_322_329_in_af2045
Ricoh AP2600 printer gives an error message of SC322
1st Laser synchronization error signal error. The 1st Laser that turns on inside of the printer can't synchronize properly to print out documents which is why this message comes up and nothing is printing. Probably is going to need to be replaced but a qualified service tech is going to need to look at it further.
Top Ricoh Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
Sudeep Chatterjee
Sudeep Chatterjee
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
