Ricoh Aficio 1035 Copier Logo
Posted on Dec 05, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Remove code error sc322 - Ricoh Aficio 1035 Copier
quennie732
Level 2:
  • Ricoh Expert 422 Answers
  • Posted on Dec 07, 2010
quennie732
Ricoh Expert
Level 2:
Answers
422
Questions
0
Helped
241320
Points
775
Its a laser issue maybe dirt on sync detector. -Carl
ERROR 322 IS DISPLAYED ON MP161 SPF
http://terraofficesolutions.com/forum/index.php?topic=27.0
Quoting from web page shown:
Ricoh Error Code 322, SC322 Fix - Printer, Copier, Fax Machine « on: October 01, 2012, 07:40:17 pm »
The Ricoh copier error code SC322 or 322 is a laser synchronization problem.
This error code can mean:
Bad LDB
Bad IPU Board
Bad Controller Board
Bad Detector Board
Check the wires between I/F and Detector.
After the polygon motor reaches standard rotation speed and the LD unit fires for 400 ms, the laser synchronization detector does not get a signal.
• wires between detector and I/F disconnected or bad
• Detector is installed incorrectly
• Detector board is bad
• IPU board bad
To reset this error try the code:
"Clear Mode"+107+"Clear/Stop" hold for 5s.
Turn ON and OFF the Main Switch.
If the problem persists you may need to contact a local service technician to take a look at your copier.
How do i clear code sc322 on nashua aficio 2016
THIS VIDEO SHOW HOW FIX IT
https://youtu.be/-DGnULMHtD4
Code error sc322
laser error code polygon mirror motor bad -Carl
2helpful
Codigo sc-322-000 copier ricoh aficio 450
sc322 is an error generally caused by a component in the laser unit. However, sometimes a faulty door switch can cause this error as well. The switches in question are the three micro-switches that change state when the right door is opened or closed. They are located on the front right side of the copier, above the fusing unit and behind a plastic cover. If you can remove these switches and test them individually, you can probably find the faulty switch. If not, you can replace all three as a set and hopefully the sc322 error will go away (once you reset the machine).
If replacing the switches do not fix the error, then the problem lies somewhere in the laser unit, possibly with the polygon mirror motor, but your best bet is to replace the whole laser assembly if you can.
Hope that helps!
Lanier LD118d showing a error sc322, how to fix
sc322 is an error with the copier's laser unit. You can pull the laser unit out and clean it up if there is toner on or in it, but more than likely either the polygon mirror motor or the laser unit as a whole assembly should be replaced.
2helpful
2answers
I HAVE AN ERROR SC 322 WHEN i GO TO PRINT RICOH 1035
Error Code SC322:
1st laser synchronization error
The 1st laser synchronization signal cannot be detected by the main scan synchronization detector board even if the laser diodes are activated.
Possible Causes:
+ Poor I/F harness connection between the laser synchronization detector board and the LD unit.
+ Laser synchronization detector board out of position and angle of reflection not correct
+ Laser synchronization detector board defective LD unit defective
Not sure what your expertise is on this, but unless you know how to service the machine yourself, this one is going to require a service call...
There have been instances where toner drops onto the LD Unit and creates problems like this. About a month ago I replaced the Laser Synch. Detector Board in a 1045 for this exact problem and error code.
I'd start by cleaning up any toner on the LD unit, and re-seating all the electrical connectors on the laser unit. If that doesn't clear things up, it's probably one of two things, the LD Unit or the Synch. Board. I'd lean more towards the Synch. Board myself, but you never know...
3helpful
Functional Problem SC322
Polygon mirror motor is bad. Sometimes you can put a drop of oil on the shaft, but at best is a temporary fix. You'll end up having to replace it. Good luck
8helpful
3answers
I need solution to aficio 200 error code sc322
sc322 is a Laser synchronization error:
Means that the laser synchronization signal cannot be detected by the main scan detector board.
Possible causes:
Poor connection of the interface harness which connects the laser synchronization detector board and the BiCU board.
Laser synchronization detector board out of position or is defective.
BiCU board is defective.
Unfortunately,unit needs service.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Ricoh AP2600 printer gives an error message of SC322
1st Laser synchronization error signal error. The 1st Laser that turns on inside of the printer can't synchronize properly to print out documents which is why this message comes up and nothing is printing. Probably is going to need to be replaced but a qualified service tech is going to need to look at it further.
Top Ricoh Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
Sudeep Chatterjee
Sudeep Chatterjee
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
