Canon MultiPASS MP360 All-In-One InkJet Printer Logo
Posted on Nov 08, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hello, I have a problem with my mp360 printer. I
Hello, I have a problem with my mp360 printer. I have not used the printer for quite a while. I set it up today and tested to print a page. The machine seemed to function fine but a blank page would be generated. Nothing was printed on the page. I replaced the inks but the problem remains. can you help?
Anonymous
Level 3:
  • Master 1,049 Answers
  • Posted on Nov 08, 2009
Anonymous
Master
Level 3:
Answers
1049
Questions
Helped
291471
Points
2705
Inkjet Printers dry out over time if they sit idol. Open the printer and remove the ink. Clean around the ink carriage and the under the ink with alcohol and a cotton swab. Pay special attention to areas with copper contacts. If the printer has a cleaning option either on the printer itself through the menu system or on the machine through the print driver, you can use that afterwards. Some printers will let you re-run the cleaning utility several times.
Cannon MP360 give me data error press set key on display
Here is my procedure to overcome the undocumented error, related to a dead buffer battery.
You can download my procedure from here as well:
https://app.box.com/s/td45r2jbau8auvgaib760mannemz4msr
This error is NOT mentioned in the user guide; it is not even mentioned in the technical repair and service manual!
If "Data Error Press Set Key" is displayed whenever connecting the Canon MP360 to the power line:
-Do NOT try the 'Set' key (arrow down), it won't work; you can only use the '-' key (arrow left)
-You will notice that the 'SCAN' button will erroneously show 'FAX' on a MP360 (it has no FAX!)
-The printer may work for COPY, but will NOT be recognized correctly as a USB device; any installation attempt under Windows (2k,XP,7..) will decline the USB device as 'unknown'.
Root cause: an undocumented buffer battery (most likely CR2450, not even mentioned in the service/repair manual, not shown on schematic drawing either).
When it is empty all settings are screwed, the data memory is corrupted or plain empty. This affects the USB connectivity as well.
This following method works to revive the printer.
Locating and replacing the dead battery is NOT mandatory. It would require major surgery to the printer case, removal of many parts.
You can continue with the dead battery, but will be forced to rerun this procedure below whenever reconnecting the power cable. Turning the printer off into standby is OK; the settings are kept in memory as long as power is applied to the printer.
1)Hold 'COPY' button while connecting printer to the power line to start the printer
2)Press 'Start' button as shown in the display
3)Press 'Set' key as shown in the display; the printer will remap the keys correctly to continue
4)Follow the flow chart below to reset the firmware; you probably do NOT need the first section "All Clear", as the memory is most likely completely wiped anyway.
In a nutshell you need to press this key sequence, i.e. the second portion of the flowchart:
1.'Additional Functions' - 'Scan' - 'Copy' - 'Scan' - several times '+'(right) to reach #5 (Type) - 'Set'
2.Leave 'FW1' for the MP360 - 'Set'(down) twice to accept the firmware and location 'USA'
3.'Stop/Reset' to finish this procedure
All this may apply to the MP370 as well; simply choose 'FW2' in this case by switching the "#5 Type" with the left/right arrow key to the alternate firmware choice.
As long as you do not unplug the printer it will now work as it should; it can be controlled via USB and execute all functions again. It will even work in Windows 10 if selecting it as MP260...
MW 05.2022
1helpful
Ip address
Click the Menu button on the printer and scroll to the Network settings to the IP address. You may need to change the IP address to suit your network.
2answers
Can not download canon imageclass mo360 driver into my new laptop
hello. You need a new driver. They are a free download at Canon.com
Printer says cartridge is jammed press the "set" but I can't find any such key
This is just an educated guess however "set" is the term used by Cannon to refer to the operation of installing a new ink tank, possible they are requesting you remove and reinstall the ink tank, ensure it is in the right slot and ensure you hear a click.
http://www.retrevo.com/r/262bh333/85/Replacing+An+Ink+Tank#q=Canon+MP360
3helpful
Canon SnartBase MP360 goes through motions of
try to unplugg it install drivers then plugg and reboot and try a teset page.
1helpful
2answers
Smartbase MP360 Scanner Not Identified by MS Vista
One thing to check and be sure of is that your printer cable (USB) is definately a USB 2.0 cable. Canon have an issue with their printers with scanners in that the data flow sometimes isn't sufficient when an older USB cable is used. The slightest drop of data on startup or during scanning will cause a stop.
Worth trying and has sometimes solved the problem for my customers.
I need the drivers for my mp360
Here's your link jsut download the appropriate one and your set
MP360 Device Drivers
cheers
MP 360 won't print
the Cartridges is Jammed on my MP360 ImageGlass all - in one Printer
Please advise me how to fix it
Thanks
Yatiha Balfour
Grand Canyon Tech
Grand Canyon Tech
Sudeep Chatterjee
Sudeep Chatterjee
