Computers & Internet Logo
A
Anonymous Posted on Aug 02, 2012
Reset adtran to default
I have forgotten how to default an Adtran 608. I know you turn off the unit and when you turn it back on you press a certain key as it is rebooting. What is the key to press?
5 Related Answers
Anonymous
  • 12 Answers
  • Posted on Jul 08, 2007
SOURCE: Adtran Atlas 550 alternatives
1: Would a Cisco 1720 provide a simple soltution for terminating a T1 to Ethernet 100 Mps I recommend a 1721 2: If this would not be an option, what Cisco box would provide the needed termination/routing I recommend a 1721 3: If a Cisco device could do this would it be necessary to replace them at both locations or could it communicate with the Adtran device. It depends on the topology of how your sites are interconnected to each other. Please describe in greater detail.
Anonymous
  • 83 Answers
  • Posted on Jun 23, 2009
SOURCE: Adtran Telnet
Are you getting any failure msgs? Where are you telnetting from? Has your router been restarted? If you have web access turned on the router, you might be able to login via your browser, or you could directly connect to your router via a console cable to check your configuration.
Anonymous
  • 223 Answers
  • Posted on Apr 29, 2011
SOURCE: I do not know the
Thank you for using FixYa
The default password is 'password' and then 'admin'
uaafqqavnaaaaaelftksuqmcc
http://docs.google.com/viewer?a=v&q=cache:2jM0LFDsYpEJ:www.andovercg.com/datasheets/adtran-netvanta-3430.pdf+Adtran+Netvanta+3430+Router&hl=en&gl=us&pid=bl&srcid=ADGEESj5spjwkyVJC6UyQDNwkyvakTTZSbWo4enx_ZgRd2xVMlQV1Xb-vUjtRni1jRfONgwG5SfKaIvKtgH0FFtuKhbjlU2nDcw8m1JheO2ZyLt3Vtv0hizo49rXEr_Ck7dj-wibAQ6B&sig=AHIEtbRallEW86bs2qN3VdcAR2SK5Nno6w
I hope this was useful and please comment if this was helpful to you.
rajendrasngh
Rajendra Singh
  • 394 Answers
  • Posted on May 19, 2011
SOURCE: How do I factory default
Every router has a reset button on it.
Try to find that button and press it for 30 Second.
It will reset your router to factory setting.
I hope it will help you.
Thanks for using FixYa.
Robert Lissor
  • 263 Answers
  • Posted on Aug 23, 2011
SOURCE: I can not log into
There should be a reset button on the back of the router take a small pin and push and hold for 30 sec that will set the router to factory defaults you will loose any settings you have on it and will have to reconfigure it I have included the manual
http://www.adtran.com/pub/Library/Manuals/Default/Total_Access_600_Series_System_Manual.pdf
Top Adtran Computers & Internet Experts
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you an Adtran Computer and Internet Expert? Answer questions, earn points and help others
