Not every router has the button. For Adtran you would need to reload the box and as soon as you see the first prompt wait for "You have 5 seconds to press escape to enter bootstrap mode." In bootstrap you can type "erase startup-config" and hit enter and then answer "y" to "Erase startup-configuration? " and reload.
You also have an option to run "bootstrap#erase file-system" but that will erase all files in the file-system which I don't recommend you do that. Erase startup-config is better.
?I hope that was helpful :)
SOURCE: How do I factory default
Every router has a reset button on it.
Try to find that button and press it for 30 Second.
It will reset your router to factory setting.
I hope it will help you.
Thanks for using FixYa.
