Adtran Netvanta 3430 Router Logo
Anonymous Posted on Apr 29, 2011
I do not know the password to acccess adtran 3430 router. how can I reset the router to reconfigure
Anonymous
Level 2:
Sergeant:
  • Expert 223 Answers
  • Posted on Apr 29, 2011
Anonymous
Expert
Level 2:
Sergeant:
Answers
223
Questions
0
Helped
39160
Points
544
Thank you for using FixYa
The default password is 'password' and then 'admin'
I do not know the - uaafqqavnaaaaaelftksuqmcc
http://docs.google.com/viewer?a=v&q=cache:2jM0LFDsYpEJ:www.andovercg.com/datasheets/adtran-netvanta-3430.pdf+Adtran+Netvanta+3430+Router&hl=en&gl=us&pid=bl&srcid=ADGEESj5spjwkyVJC6UyQDNwkyvakTTZSbWo4enx_ZgRd2xVMlQV1Xb-vUjtRni1jRfONgwG5SfKaIvKtgH0FFtuKhbjlU2nDcw8m1JheO2ZyLt3Vtv0hizo49rXEr_Ck7dj-wibAQ6B&sig=AHIEtbRallEW86bs2qN3VdcAR2SK5Nno6w
I hope this was useful and please comment if this was helpful to you.
  • Anonymous Apr 29, 2011
    Set your PC to a fixed address of 10.10.10.2 and then enter the modem by typing in 10.10.10.1 in your browser. Power it off and on when making changes. User name is "admin" password is "password."
Four got my password need help
when logging in to your router configuration the default username is admin and leave the password field blank and click log in. the last resort is to hard reset your router and reconfigure it.
Note: hard reset is located at the back of your router you will see a tiny hole and labeled reset. This is advisable only for those who knows how to reconfigure the router because by hard resetting the router it will go back to the factory settings/default.
I can not log into my adtran 624 router. How do I reset password?
There should be a reset button on the back of the router take a small pin and push and hold for 30 sec that will set the router to factory defaults you will loose any settings you have on it and will have to reconfigure it I have included the manual
http://www.adtran.com/pub/Library/Manuals/Default/Total_Access_600_Series_System_Manual.pdf
How do I factory default adtran netvanta 1224st?
Every router has a reset button on it.
Try to find that button and press it for 30 Second.
It will reset your router to factory setting.
I hope it will help you.
Thanks for using FixYa.
1helpful
Is there a way to perform local password recovery on a Netvanta 3200 router?
can you not reset it, there should be a small hole at the back of the router
just push the point of a pen in the hole and that should reset it..
Can you please advise how to do the password recovery on Adtran Netvanta 1335
Call ADTRAN Technical Support at 1-800-4ADTRAN and they will be happy to assist you.
I lost my wrt350n rooter password. Are there way ...
think you need to reset the router and reconfigure it . There is a small reset button on the router. Press and hold it for 30 seconds. Remember if you reset the router, you will lose all the router settings and you will need to reconfigure it . Follow link to reset linksys router
Password apparently lost on Netvana 3200 - any hidden reset?
http://kb.adtran.com/display/2n/articleDirect/index.asp?aid=1786&r=0.6352198
connect console cable
Bootstrap# bypass passwords
Bootstrap# boot
3answers
Forgot linksys router password
Reset the router. Thats the only solution.It will get back to facotry defaults.
Thanks
Ranjit
Netvanta reset password
Enter admin as the username, enter your admin password, and click the OK button. (The default password is
password.) Here is a link to your manual:
http://www.wedophones.com/Manuals/Adtran/NetVanta%202000%20Series%20Quick%20Start%20Guide%20(Rev%20B)%202nd%20gen.pdf
Can see the wireless network, but can not find the password to log on.
Do you know how to access your linksys router? Do you know the password on the linksys router?
If not you will need to reset the linksys to restore the password to it's default and then reconfigure the router from scratch.
To reset the router use a ballpoint pen end press 10 seconds on the reset button in the back (ATTENTION: YOU WILL NEED TO RECONFIGURE THE ROUTER)
Once you reset it the password to access the router is admin. Connect to the router using a cat5 cable, point your browser to : http://192.168.1.1
leave the user field empty and type admin in the password field.
You can now go ahead and reconfigure it.
Top Adtran Computers & Internet Experts
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you an Adtran Computer and Internet Expert? Answer questions, earn points and help others
