20 Most Recent Toshiba e-STUDIO 282 Black and White Copier Questions & Answers
4answers
I need the default password for a toshiba estudio
Toshiba e-Studio series machines typically use 123456 as the factory default password. This should work unless it has been changed.
6/26/2022 10:19:52 PM • Toshiba e-STUDIO... • Answered on Jun 26, 2022
How to solve error code c430
If 1st time occur, u can just go to 08-400, reset the value to "0" then restart the machine.
When this code not cleat 08-400 then check these all thengs..1.Check the thermistors (1) Check if the connectors are disconnected.(2) Check if the main and edge thermistors are in contact with the surface of the fuser roller properly?(3) Check if the harnesses of the main and edge thermistors are open circuited.2. Check the IH board and IH coil(1) Check if the IH coil is broken.(2) Check if the connector of the IH coil is disconnected.(3) Check if the thermostat is blown.(4) Check if the connectors on the IH board are disconnected (AC input connector and LGC I/F connectorCN455/456).(5) Check if the IH board or the switching power supply unit are abnormal.• Replace the IH control board.3. Check the LGC board(1) Check if the connectors CN316 are disconnected.(2) Check if the conductor pattern on the LGC board is short circuited or open circuited.(3) Replace the LGC board.please vote me.Thanks Best Regards
    7/11/2018 6:27:20 AM • Toshiba e-STUDIO... • Answered on Jul 11, 2018
    Toshiba e-280 shows F-120 error code, i dint find
    [F120] Database abnormality
    What you can try to do is go into (08) mode by holding the 0 and 8 keys while turning on the copier. Once it comes into test mode key in 684, this rebuilds the databases. If this doesn't fix it go into (08) mode again and key in 690 and press start, key in 2 and just hit start again. This formats the HDD and hopefully the copier will work after that. If not you will likely have to replace the HDD.
    Note: When you format the HDD it clears out only information such as address book and templates.
    5/10/2018 3:58:22 PM • Toshiba e-STUDIO... • Answered on May 10, 2018
    Toshiba e studio 282 error code E 010
    E010 is a jam up in your fusing unit. Chances are on that model, you have a pickoff finger stuck in an up position. Check for that, if there is just push it back down with a pencil. Otherwise you may have other problems and will need to contact a Toshiba Authorized Retailer for help.
    10/12/2017 2:10:59 PM • Toshiba e-STUDIO... • Answered on Oct 12, 2017
    How passward is installed on studio e 282
    123456
    10/12/2017 1:59:00 PM • Toshiba e-STUDIO... • Answered on Oct 12, 2017
    Hi, we have a toshiba
    https://www.youtube.com/watch?v=3aqJtimew-w see time 1:30 - 1:44 on video See the man opening the duplexer tray and removing paper jam !
    7/15/2017 1:23:08 AM • Toshiba e-STUDIO... • Answered on Jul 15, 2017
    E studio 230
    Carriage home position sensor not turning ON
    6/26/2016 4:39:05 PM • Toshiba e-STUDIO... • Answered on Jun 26, 2016
    Problam in F-100 Singnal
    Format HDD
    6/26/2016 4:37:58 PM • Toshiba e-STUDIO... • Answered on Jun 26, 2016
    F103 error code in 452 e-studio toshiba copier
    (1) Check if the connectors of the HDD are disconnected. (2) Check if the connector pins are disconnected or the wires of harnesses are broken. (3) Perform the bad sector check (08-694). If the check result is OK, recover the data in the HDD. If the check result is failed, replace the HDD. (4) Replace the SYS board
    6/26/2016 9:16:55 AM • Toshiba e-STUDIO... • Answered on Jun 26, 2016
    2answers
    Toshiba estudio 282 has error code cc90--how to
    good day cc90 is the top tray of your finisher (sorter) is causing the fault it is usually caused by there was something heavy put on the top tray or somebody bumped the tray. the bushes on the tray that is lifted by the motor are faulty and need to be replaced by a qualified technician if you need to use the machine please switch off the machine and unplug the finisher (sorter) switch on and the machine will work and obviously not sort or staple i hope that this quick fix will help you out until a technician can repar your finisher (the plug for the finisher is at the back of the machine above the power inlet behind a small cover)
    3/31/2015 12:39:50 PM • Toshiba e-STUDIO... • Answered on Mar 31, 2015
    Reset admin passoword e-studio 280
    Code 282 is returned to the manufacturer Toshiba
    1/20/2015 11:40:45 AM • Toshiba e-STUDIO... • Answered on Jan 20, 2015
    How to fix code c440
    C440-Heater abnormality after abnormality judgment: The temperature of the fuser roller has exceeded the range of control or does not even reach the range. You can try going into (08) mode by holding 0 and 8 while turning on the copier. Once the copier starts up key in 400 and press start, input "0" and press interrupt. Try rebooting the copier, if this doesn't clear that call for service then you are going to need to get work done on your fuser.
    7/31/2014 7:57:35 AM • Toshiba e-STUDIO... • Answered on Jul 31, 2014
    282 auto shutdown clearing mode command
    go to user or energy saver key you will find shutdown
    7/6/2014 7:29:50 PM • Toshiba e-STUDIO... • Answered on Jul 06, 2014
    My e studio 232 toshiba has a problem in back to back copy, everytme i use it the copy out adjust more or less one inch down please help me
    Clean feed rolls with wet cloth and lubricate registration clutch.
    7/6/2014 6:22:06 PM • Toshiba e-STUDIO... • Answered on Jul 06, 2014
    HDD has crashed
    check if there is a bad sector on your hdd, using hard disk checker software for bad sectors, if it has you need to replace it and backup your files. asap.
    6/16/2014 2:01:59 PM • Toshiba e-STUDIO... • Answered on Jun 16, 2014
    make sure the guides in the paper tray is in aligment with the correct size markings
    6/15/2014 9:06:51 PM • Toshiba e-STUDIO... • Answered on Jun 15, 2014
    if you are using the adf, try to check the timing of the rollers...your magnetic clutch might need some cleaning...the moving down or moving up of image is usually caused by missed timing in adf and paper...
    5/25/2014 8:42:36 AM • Toshiba e-STUDIO... • Answered on May 25, 2014
    Toshiba e-STUDIO 282 Black and White Copier Logo
    107 questions posted
    Top Toshiba Office Equipment & Supplies Experts
    Norman Weimar
    Norman Weimar
    Sudeep Chatterjee
    Sudeep Chatterjee
    Grand Canyon Tech
    Grand Canyon Tech
    Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
    View Most Popular
    • Toshiba Office Equipment & Supplies
    Most Popular Question
    fix code c440
    • Office Equipment & Supplies
