Toshiba e-STUDIO 282 Black and White Copier Logo
B
Bernard Butchie Gubatan Posted on May 24, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My e studio 232 toshiba has a problem in back to back copy, everytme i use it the copy out adjust more or less one inch down please help me
Mahabob Basha.T
Level 2:
New Friend:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 115 Answers
  • Posted on Jul 06, 2014
Mahabob Basha.T
Expert
Level 2:
New Friend:
Cheetah:
Answers
115
Questions
Helped
19957
Points
118
Clean feed rolls with wet cloth and lubricate registration clutch.
5 Related Answers
Anonymous
  • 87 Answers
  • Posted on Dec 16, 2008
SOURCE: how to reboot my toshiba E-Studio 232 black and white copier?
if u want to reboot hard **** just go to 08 mode .then press 690 press start .2 is normall format .shut power off when reboot machine appears .
didi2005
  • 727 Answers
  • Posted on Jun 10, 2009
SOURCE: Toshiba e-Studio 232 is showing error message CF60
CF60 indicates Recycle Toner Transport area lock. U need to take out the process unit, remove developer unit, remove drum, drum blade & recovery blade, disposed all waste toner, make sure the gear can turn properly. Then reassembly back everything.
Anonymous
  • 3 Answers
  • Posted on Apr 11, 2010
SOURCE: toshiba e-studio 232 says c440 code
This problem is caused by the thermister in the fuser section. To reset shut macine off, then turn it on while holding down the 0 and the 8 key down for more than ten seconds then release. This is service program mode, now press 4 then 0 then 0 and then the start key, you will see a nuber in the screen, press 0 then start key this should reset that code if not the thermisters need to be replaced
Anonymous
  • 66 Answers
  • Posted on Sep 01, 2010
SOURCE: how to clear time for periodic mintenance display
Go into (08) mode by holding 0 and 8 when turning on the copier. 251 is the number of copies until it displays that message and 252 is the count since last Preventative maintenance. Resetting 252 will clear the message or putting 251 higher than the value of 252 will clear it as well.
Anonymous
  • Posted on Dec 09, 2010
SOURCE: unable to access scan folder
Connect to copier/scanner using web browser. Click Administration tab, and logon use the copier's username/password. Click Network Click SMB Session Click SMB Session box In section called "SMB Signing of SMB Server", the default of "If client agrees, digital signature is done for communication" needs to be changed to "Digital signature isn't done for communication for the server" Click Set button at top, then Save button, and the copier will reset.
Top Toshiba Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
Sudeep Chatterjee
Sudeep Chatterjee
Grand Canyon Tech
Grand Canyon Tech
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
