20 Most Recent Victory URD-27-SBS Stainless Steel Questions & Answers
Fridge lights flashing on and off, and inadequate cooling
could be a few things. sounds like the compressor is going. put a thermometer in it and play with the temperature settings.might have a short somewhere.
5/24/2009 3:19:53 PM • Victory... • Answered on May 24, 2009
Victory Refrigeration VR-2 V-Series 2-Door Reach-In Refrigerator. E-6 error. Potentiometer failure? If so? Help?
Question edited for a lot more clarity, full make model and 'potential' to 'potentiometer'. Is this the part, it is like a volume control which is what a potentiometer is for, regulating voltage? This is for a Dellfield refrigerator and the only place I find the E6 error is on the Parts Town website. And that is a ridiculous price for a $10 part! https://www.partstown.com/cm/resource-center/guides/gd1/delfield-refrigerator-troubleshooting E6 isn't listed as an error in the Victory Service Manual https://www.manualslib.com/manual/825120/Victory-Reach-In.html?page=10#manual Get your money back from Parts Town and put it towards a service call. ..
3/10/2023 8:10:12 PM • Victory... • Answered on Mar 10, 2023
0answers
3answers
Our lamona wine cooler 300mm is not chilling the
We get the same. Every 10 or so seconds the internal fan kicks in. Called the warranty line whom sent a new fan and an engineer. The engineer said there was no issue with it and checked with the manufactorers. He assured me it was normal and was simply to keep the cool air moving around the bottles to maintain optimum cooling across all the wine. I questions the longevity of the fan due to the constant on off process. He said its a brushless motor fan and simly relies on an electrical current to power it. Ie no actual motor component.
I asked that the help line have this info to hand as it appears to be a normal operational aspect of the unit. I guess lots of people will call the helpline with the same question.
Hope this helps
1/31/2013 5:17:34 PM • Victory... • Answered on Jan 31, 2013
0answers
3answers
I have samsung refrigrator model
The defrost is not working and the fan is hitting ice buildup...
Check out these tips...they can help you figure out what is going wrong with your refrigerator
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
7/23/2026 5:43:15 AM • Refrigerators • Answered on Jul 23, 2026
3answers
Does the 406-CA fridge require cleaning maintenance?
Most refrigerators need little maintenance. However you should periodically check condenser coils and clean as dust on these reduces their operation in condensing the refrigerant gas. Also clean the evaporator coils (if you can access) to again enhance operation. A general clean of the inside will make unit look good and possibly remove old products.
7/23/2026 5:38:01 AM • Refrigerators • Answered on Jul 23, 2026
3answers
Door isn't closing properly has a 2 inch gap at bottom how do I adjust it please
Check Your Hinges in Place at Body & door of your Fridge. Check for Any mis alignment of fridge Door on its body. Check for improper Rubber gasket on Door.
7/23/2026 5:36:16 AM • Refrigerators • Answered on Jul 23, 2026
How do. Change the water filter.
To change a refrigerator water filter, locate the filter inside the refrigerator or behind the base grille. Turn the old filter counterclockwise or press the release button and pull it out. Insert the new filter, twist or push it into place until it locks, then run several glasses of water to flush the system.This video shows how the fridge's water filter works and provides how to install a new replacement water filter:https://www.youtube.com/watch?v=VlO56rAJzzwReplacement refrigerator water filters can be found here also:https://www.repairclinic.com/Shop-For-Parts/a4c43i183/New/Refrigerator-Filter-Water-Filter-PartsDifferent refrigerator models may have slightly different water filter installation steps.
1/13/2026 2:30:54 PM • Refrigerators • Answered on Jan 13, 2026
2answers
Water leaks when filling ice maker no water to ice maker
Turn off the ice maker and check the fill tube for ice or blockages, thaw if frozen. If clear, replace the water inlet valve at the back of the fridge (most common fix). Also inspect water lines for leaks or cracks and ensure proper water pressure.
10/13/2025 8:38:39 PM • Refrigerators • Answered on Oct 13, 2025
2answers
Why is food freezing in my fridge?
Check the thermostat is sett aroung centre position.
10/13/2025 8:29:08 PM • Refrigerators • Answered on Oct 13, 2025
3answers
Cannot lower temp
Mention Specific Brand of Refrigerator: heck you thermostat and replace same is faulty. Check for Controller on panel having Switch or Rotary Switch.
10/13/2025 8:08:59 PM • Refrigerators • Answered on Oct 13, 2025
We have a Kenmore Elite refrigertor. The ice
hi,please remove ice maker see if an ice is jamming it up first...second on the freezer ,when you open it up...is there a switch on the wall..that is a infrared for the icemaker,,if so switch it off...remove ice maker...check it first....if its ok...possible problem with sensor...check these things,,,is filter ok...is water coming out of door,dispenser...then filter ok....good luck call if need assistance,,,michael,,doctor airr appl.repair..843-384-8474...
10/5/2025 8:46:09 PM • Refrigerators • Answered on Oct 05, 2025
I need to recharge my 1990 sub zero refrigerator with r12, but all i can find is "auto" r12... does it matter if its auto?
refrigerator compressors and auto compressors are different beasts entirely. unlike automobile compressors, refrigerator compressors run within the atmosphere of the refrigerant, that's why it is called a "sealed system" on a refrigerator. On an automobile, the a/c compressor pumps outside the atmosphere, in other words, it pushes a piston through a seal to compress the refrigerant. This is also the reason it is not uncommon to need to have refrigerant added to an older automobile a/c system. If this happens on your refrigerator, the system is compromised and you should have a local refrigerator repair service do this since special tools and equipment are needed.
9/3/2025 8:04:50 PM • Refrigerators • Answered on Sep 03, 2025
Victory URD-27-SBS Stainless Steel Logo
2 questions posted
Top Victory Refrigerators Experts
ADMIN Andrew
ADMIN Andrew
Ottoniel
Anonymous
Are you a Victory Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Victory Refrigerators
Most Popular Question
fridge lights flashing off inadequate
  • Refrigerators
