If the auger motor has been replaced and the ice dispenser still doesn't run, the issue is usually upstream of the motor, not another relay by itself.
First, remove the ice bucket and press the dispenser with the freezer door switch held in. If you don't hear the motor hum or see the chute door open, the most common causes are the dispenser switch, wiring harness, or dispenser control board. A frozen chute or misaligned bucket can also prevent operation even with a good motor.
Model-specific dispenser components for GI6FDRXXY02 can be found here:
https://www.repairclinic.com/ProductDetail/902424
https://www.repairclinic.com/Shop-For-Parts/a4/Refrigerator-Parts
For step-by-step diagnostics on what to test next, this guide walks through the dispenser not working common problems:
https://www.repairclinic.com/RepairHelp/How-To-Fix-A-Refrigerator/54---/Refrigerator-Ice-Dispenser-Not-Working
Go back to the basics. Water flow. Temperature.
SOURCE: GE Profile Refrigerator will not dispense ice.
see http://applianceguru.com/view_topic.php?id=13243&forum_id=1&jump_to=76889
SOURCE: Fridge won't dispense ice through door.
First take the hopper out and let it de-ice completely making sure that it is dry before re-installing it. Make sure that the auger moves when re installed with no ice in it.
SOURCE: GE refrigerator model GSS22 WGMD ice maker motor
If you cant manually turn your auger motor, it may be bad. Does it dispense solid ice or no ice at all? Another thing may be your control panel. That could be bad too, it's the one sending juice to both your solenoid and auger motor.
SOURCE: Ice maker makes ice but can't dispense ice
Please try this. Remove your Removable Ice Bucket Assembly which is where the Auger (corkscrew) is located. You should be able to see the Auger Motor Drive Fork which is located permanently inside the freezer compartment... opposite the end of the Removable Ice Bucket Assembly that you just took out. Close the freezer door and attempt to dispense ice... if you can hear the Auger Motor running as you attempt to dispense ice... then the Auger Motor is OK. Dump out all the ice that is in your Removable Ice Bucket Assembly and wash it out in your kitchen sink with warm water. Reach into your freezer and put your hand on the Auger Motor Drive Fork ... you should be able to rotate it CW or CCW...it is a little hard to turn but it will turn. Position the Auger Motor Fork to a 12:00 and 6:00 o'clock position. Now take your Removable Ice Bucket Assembly and position its Receiver Auger Fork to a 9:00 and 3:00 o'clock ....Re install the Removable Ice Bucket Assembly into the Auger Drive Fork. Close the freezer door and again attempt operate the ice dispenser... you should hear the Auger Motor again run as you press the ice dispenser. Note....at this same time the Ice Chute Door in the Freezer Door should spring open so that ice can fall out. Of course you have no ice in the Auger at this time...but it all this works then future production of ice will fall out. Note...Usually the Auger Motor never fails. but the whole thing can get jammed with ice and not dispense. Also, the the solenoid that operates the Ice Chute Door fails quite frequently. Last but not least... if nothing is happening... it is a control board type problem. Hopes this helps! Handy Henry
If you need further help, Iām available over the phone at https://www.6ya.com/expert/henry_239f63a136de60f0
SOURCE: Whirlpool Door Ice Dispenser Not Working
mine froze up in the shute, had to put water down iti
