20 Most Recent Tyan S7025 (S7025AGM2NR) Motherboard Questions & Answers
Clear cmos jumper jbat pins
It is safer to remove the battery for two minutes. If there is any residual charge in the system, and you use the jumper, you can damage the motherboard. If you insist on using the jumper: First unplug the power supply then push the start button to ensure the system has no charge, then change the jumper for about ten seconds. Put the jumper back in the original position, plug the power supply back in, and you can boot he system .
7/6/2015 2:48:19 PM • Tyan S7025... • Answered on Jul 06, 2015
What BIOS menu option is used to configure the I/O address and IRQ for the first serial port
It is on the Super I/O Configuration Sub- Menu of the BIOS which can be found on the Advanced Page. The actual setting is called Serial Port 1 Address. Information was taken from the online user manual for the motherboard. http://www.tyan.com/manuals/S7025_manual_20140508.pdf
9/8/2014 4:19:33 PM • Tyan S7025... • Answered on Sep 08, 2014
0answers
Motherboard burned
if *********** board is integrated then just throw it away.. and if it is non-integrated then u must call up to hardware engineer .. who can sort out *********** board problem
6/14/2011 4:14:41 PM • Tyan S7025... • Answered on Jun 14, 2011
Error code d4
There is a conflict in shadow ram. Check the add-on cards. It may be necessary to disable the BIOS shadow into RAM in order to make space for the other cards ROM
7/9/2015 6:53:23 AM • Tyan Computers &... • Answered on Jul 09, 2015
Red light 03 motherboard s5512wg
This error is "Initial Superio_Early_Init switch" This error occurs when The first memory module is bad or the BIOS is corrupt. Exchange RAM. If that does not work, Reset the BIOS by removing the battery for two minutes If that does not work, replace BIOS; or motherboard.
7/8/2015 5:59:09 PM • Tyan Computers &... • Answered on Jul 08, 2015
How do i reset the password on a Tyan m3296 SMDC
contact Tyan and request support, just say that the hardware was in a machine you were given. It might be that that there is a generic password built int the firmware. Such a practice is common on most electronic equipment, hope you are lucky. Otherwise look for an answer on Tyan forums or Tom's Hardware
5/25/2015 10:03:08 PM • Tyan Computers &... • Answered on May 25, 2015
Memory card slot jumper setting nokia 112
http://mobile-care.blogspot.com/2013/04/nokia-110-and-112-lcd-light-jumper.html
5/23/2014 4:25:02 AM • Tyan Computers &... • Answered on May 23, 2014
Motherboard tyan s5167
here you go http://www.tyan.com/support_download_manuals.aspx?model=S.S5197
5/18/2014 8:53:19 PM • Tyan Computers &... • Answered on May 18, 2014
Motherboard Led codes
Is this a bios error code onthe onbaord diagnostics? As this is a server board be careful - reset the bios to defaults is the first step in solving motherboard issues. Remove all cards and begin testing - remove all ram chips except one and test replacing stepwise until you have isolated the issue - usually the bios error code is the last item to pass before failure. Looks like it could be DMA controller failure but you would need the manual for the board to be sure.
5/13/2014 11:37:47 AM • Tyan Computers &... • Answered on May 13, 2014
USB 2.0 on Tyan S1845 Trinity 400 Motherboard
look at board near front panel on the sides
4/3/2014 4:45:38 AM • Tyan Computers &... • Answered on Apr 03, 2014
0answers
Tyan d1808
Be the first to answer 10/21/2013 9:15:04 AM • Tyan Computers &... • Posted on Oct 21, 2013Be the first to answer
Code e1 on a s2668
It is a bridge initilization error according to the manual. I would try removing the memory and just use 1 module and see what happens. If that doesn't work, try pulling other components, including the video card to see if you can isolate the problem.
10/31/2012 9:17:05 PM • Tyan Computers &... • Answered on Oct 31, 2012
Tyan S7025 (S7025AGM2NR) Motherboard Logo
7 questions posted
Top Tyan Computers & Internet Experts
ADMIN Andrew
ADMIN Andrew
Anonymous
Level 1 Expert
Are you a Tyan Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Tyan Computers & Internet
Most Popular Question
clear cmos jumper jbat pins
  • Computers & Internet
