Tyan S7025 (S7025AGM2NR) Motherboard Logo
Posted on Jul 02, 2011
Just built the server using a Tyan S7025WAGM2NR board. I went to set up the RAID and can not seem to make the system recognize the drives. I'm using Xeon processors (5600). any suggestions on how to configure the RAID?. I see where several people have added separate RAID cards to this same board. Is that the answer?
5 Related Answers
Anonymous
  • 40 Answers
  • Posted on Sep 28, 2009
SOURCE: No video at all
try first with one cpu and only one stick of memory in socket zero
if the video does not come on... try next to reset the bios .. clear the settings... it may be setup to search for a pci or pci-e video card in the bios
next try to test the wattage being pulled into the system at boot... should be over 200watts.. may indicate a power issure
are there any beep codes ... post codes or ... is there a single beep tone during power on to verify the motherboard is functional and checks out fine at self start...
mark@omces.com
Anonymous
  • 40 Answers
SOURCE: Tyan S5396 and Thermaltake 1500W
tyan i5400xt.. to test for ground.. pull the board from the chassis and test with a different known good power supply
if the boot works... then you have a power supply issue...
does the board have a post code lighted signal ???
if so.. a bad power supply should goto FF error code
verify you have enough power on the cpu rail with your power supply specifications also
be sure you have all cables 4 pin 8 pin and 20/24 pin connections done correctly.. lastestly check if the board is touching the chassis edge anywhere... could cause a ground
also take and loosen all the MB screws from the chassis.. just let it hang there this will test the grounds needs the screw connections
mark@omces.com
tyan specialist
Ezrahite
Rofel Lantican
  • 2632 Answers
  • Posted on Apr 07, 2011
SOURCE: I get no video, after
Hi Patrick,
Welcome to Fixya. The Tyan M-8110 SATA Raid Card did you connect it to the Two independent PCI/PCI-x port on the motherboard. The 2 smaller white PCI port. ezrahite_88.jpg
If you have questions please let me know. Thanks
Anonymous
  • 1961 Answers
  • Posted on May 04, 2011
SOURCE: Tyan S2735, i7501(new build) two
Hello!
If you boot your PC did you hear beep codes. Please post it here, the pattern of the beep sounds. It could be a short beep, a long beep and the number of times it beeps. It's very important cause it tells where in the hardware of your pc is faulty.
bronk50
Brian Sullivan
  • 27725 Answers
  • Posted on Dec 10, 2012
SOURCE: I am getting a BIOS POST error (87h) from system start to O.S. desktop
If you want to know what this is the error code is related to
Click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured or click start type in event viewer press ENTER you might be able work your way through the problem
if you need more help with this post a reply with the error message details so that someone might be able to provide a solution
Hope it helps.
Top Tyan Computers & Internet Experts
ADMIN Andrew
ADMIN Andrew
Anonymous
Level 1 Expert
Are you a Tyan Computer and Internet Expert? Answer questions, earn points and help others
