Precor 956 Remanufactured Treadmill Logo
A
Anonymous Posted on Jul 15, 2011
Hello I have an error 45 what is this? - Precor 956 Remanufactured Treadmill
Electro Med Services
Level 3:
  • Precor Master 6,694 Answers
  • Posted on Jul 15, 2011
Precor Master
Level 3:
Answers
6694
Questions
Helped
1917113
Points
21434
Error 45 means the lift moving in wrong direction.The lift control system has detected that the lift is moving in the opposite direction of the issued lift command. There are two possible causes they are,
1- Lift Motor hysteresis.
This error would typically happen when the lift was already in motion (typically downward) when a lift command in the opposite direction (lift up) was issued. Some motors exhibited a very long turn around time and the lift motor would still be moving in the original direction (downward) while the control system was attempting to move the lift in the opposite direction. If the error 45 condition is persistent, replace the lift motor.
2 - Bad lower PCA
This is a very rare condition, if the lift moves in the opposite direction of the issued lift
command, replace the lower PCA
ok
Dish network error 31 12 45
I use Dish and have had no signal at all. The error codes are Tuner 2 31-12-45 and tuner 1 11-12-45
Error 45 on opening e mail, solution
Problem loading message: Error Code 45If you received an error code 45 when attempting to load a message, you'll need to contact us to resolve this error.
To contact Yahoo about receiving an error code 45 message:
  1. Select Contact Customer Care on this page to go to the help form.
  2. In the form, select:
    1. Your version of Yahoo Mail
    2. Category: Notices and errors
    3. Sub-category: Received temporary error code
  3. Provide these details for at least one message that produced this error:
    • Contact name and email address
    • Date message was received
    • Message subject line
    • The folder containing the email (Inbox, Spam, etc.)
    • How you attempted to open the message when the error displayed (from a folder, from email search results, etc.)
Sep 05, 2013 • Yahoo Mail
I just want to know what it errore 45???????
Hello, The system error codes are for kodak diagnostic purposes only. just like you vehicle stores trouble codes for the tech to obtain info for locating system problems. Needs to be serviced.
Best Regards, Russell
Error 45
Hello, The error code 45 indicates that the camera needs service/repair. You need to take it to a camera shop for them to determine the problem.
Getting an error code E 45
Error 45 in your camera clearly indicates it is related to a lens issue. Something has caused the lens to jam or stop working. When it does you get the E45 error you have to update the firmware and the error should go away.
Thank you !!
1helpful
In yahoo account There was a problem accessing your account. Please try again in a moment. Error #1
Hello and thank you for using Fixya!
This usually indicates that the Yahoo! server is busy. This happens frequently with Yahoo! as they have many users. It should be fine in 30-45 minutes.
Jennifer
Dec 21, 2009 • Yahoo Mail
8helpful
Kodak digital camera V705 -error 45
Hi!
E45 means that a focus error occurred or the MCU BOARD malfunctioned. I'm afraid you will have to give it away for a repair. It's a hardware problem. You should contact your local Kodak service center.
Tom
2answers
Toshiba E-Studio 45
yes it detects that the level of toner is too low, it will keep printing up to a point and then shut down.
Bad Disc Errors
are they disks you burnt?
Top Precor Exercise & Fitness Experts
Grand Canyon Tech
Grand Canyon Tech
Ngoro
ADMIN Andrew
ADMIN Andrew
Are you a Precor Exercise and Fitnes Expert? Answer questions, earn points and help others
