Microwave Ovens Logo
Posted on Jul 14, 2011
How do I install a kitchen faucet loop clip on a Moen single faucet handle? Part number 0-3067.
5 Related Answers
Dale Mullen
  • 9 Answers
  • Posted on Nov 28, 2008
SOURCE: Repair cartridge in Moen Monticello single handle lavatory faucet
After some additional experimenting, contrary to information I was previously able to gather, I discovered that the white plastic retainer doesn't (in this type of Moen faucet) actually screw off but rather is held in place by a spring clip inserted from the rear of the retainer (toward the wall side of the basing). Simply sticking a small screwdriver in the opening (approx. 45 degrees downward) and tipping the screwdriver toward the front of the faucet, snaps the spring clip out through the opening.
The plastic retainer than lifts off. Note: the flat sides on the retainer suggest that a wrench will be needed but such is not the case.
Anonymous
  • 152 Answers
  • Posted on Feb 23, 2009
SOURCE: Leaky faucet
Finding brand specific replacement parts in stock for a 20+ yo faucet without a Mod.# is quite the task, implying that you would have to do a side by side compareson/inspection. If in fact that part is not obsolete.
Maybe you should consider replacing the entire faucet.
Good luck
Anonymous
  • 58 Answers
  • Posted on Jun 09, 2009
SOURCE: how do I take apart a moen 8710 single handle
The top pops off and there is a crew under it. It's all pretty easy but when you put it back together you have to do a tricky angle kick with the handle. Watch carefully as you take the handle off and put it on and off several times to see what is needed. If you do it wrong the handle sets on top of the black thing and doesn't work right, The cartridge in the faucet pulls out with difficulty if you have hard water. There is a little clip near the the top that holds the cartridge in. You should be able to get a repair kit that has the cartridge and new O-rings for the spout.
Bill Johnson
  • 306 Answers
  • Posted on Jul 24, 2009
SOURCE: Moen Single Handle Shower Faucet leak...
the cartridge if defective,replace it and your leak will stop.
1stBSP
Steven Foerst
  • 52 Answers
  • Posted on Apr 06, 2010
SOURCE: I have a Moen Single Handle kitchen faucet, it's
Replace the "O" rings that are behind the spout portion. You will have to remove the top of the faucet and pull up on the spout section. There will be a couple of "O" rings there. It is best to have Moen send the parts to you as locating the proper size "O" rings can be difficult.
1helpful
Just put in a new moen kitchen faucet, why does it have hardly any water pressue?
You might have a clogged aerator screen. Remove the aerator from the faucet and see if the flow is normal. You can rinse the aerator off if it's clogged. It's also possible the stops (shutoff valves) aren't open all the way. Sometimes, if they're old, they don't turn on fully again after you shut them off to put in the new faucet. If you still have low pressure after removing the aerator, you may need to replace the valves.
I don't know if the instructions mentioned it, but it's good practice to remove the aerator and run a faucet to flush the water line after installing it. There's usually a lot of debris that comes through at first. That's usually why you'll have low pressure in a new faucet.
Moen 7700 kitchen faucet leaks at base of spout
The cylinder which surrounds the bottom of the spout is part of the spout. The cylinder is sealed with o-rings at top and bottom. They probably need replaced. Feel free to use lubricant.
:o).
2answers
Moen 7600 kitchen faucet leaking from around handle
You will need to replace the cartridge....
here is tutorial on how to do that...
http://www.ehow.com/how_7241891_do-repair-moen-7600_.html
If you find that the cartridge will not come out you may have to purchase a Moen cartridge removal tool... you can get them at Lowe's or many othere plumbing supply houses....
http://www.bing.com/search?q=moen+cartridge+puller&form=HPDTDF&pc=HPDTDF&src=IE-SearchBox
heatman101
I have a moen 7637 single handle kitchen faucet that leaks around the stem. How do I take the lever off.
1) Use a small sharp-pointed knife and pop out the little plastic Moen logo at the bottom of the front side of the handle (and don't lose it!)
2) Lift the lever up a bit (the water may turn on) until you can see a small screw with an allen wrench socket.
3) Unscrew the allen-head screw; the handle will lift straight up.
Look down into the faucet; there's a philllips head screw. The leaking may simply be caused by this screw being loose.
3answers
Have just installed glacier bay faucet model #8181/ 785 564 single handle with pull-out sprayer. once pulled out the sprayer will not re-seat into the faucet but hangs out about an inch or two. have...
Take it back to HD or Lowes where you got it and trade it in for a Delta....you will be glad you did... this is only the beginning of your problems....you get what you pay for...
heatman101
I have a price pfister kitchen tap and it doesn' have a cap. how do i get the handle off to replace the cartridge
If this is the single-handle faucet I remember, there's a decorative hot/cold indicator on the front, a small half red/half blue circle. This pops out of the handle to reveal the retaining screw underneath. It's a hex-key (Allen key) screw but I don't remember the size. Once you've loosened the screw you'll be able to lift the handle off the faucet body to get at the cartridge housing.
We have semi-successfully replaced our Moen cartridge for model 100940. We have no more leaks, the only problem is that the water will not stay on. When we lift the handle up, it immediately starts to...
I know this is an old question, but I just had this issue when replacing the cartridge in my 100940 J1 Moen faucet. I had to tighten the Phillips-head screw down a little more that holds the plastic piece on to the cartridge stem. Hope that's the fix you needed.
I purchased the Danco 80701 "Repair Kit for Delta, Aquasource, and Glacier Bay Faucets with #70 Ball" so that I can repair a leak in my Delta kitchen faucet. The instructions on the package are...
Sounds like the old style center-control delta type faucet, rubber washers describe older type but still good. The rubber seats have holes in middle, supply water to the cylinder which diverts water to the spout, and has a seal over top of ball allowing stem for handle.
Think they are talking about flex-hose type faucet accessory getting clogged, Maybe: lift the flex-hose faucet housing off the center-control faucet body? Water to it runs directly from center-control faucet and if broken seat gets in narrow line could inhibit spray.
Kitchen faucet spout too has an O-ring under where it connects to the faucet body. Unscrew large nut where meets the faucet body unit (slip-joint pliers), once free of threads, spout should pull straight up, easy or slight tug. I use bent paper clip to remove old one trying to save it in one piece so as to get exact size (that's important) to replace, push on one side then other.
2helpful
I have a Moen 98043 kitchen sink faucet that is leaking water from the top, any ideas how to fix
Hi Adonish,
If you give Moen a call at 1-800-BUY-MOEN someone will be able to assist you and figure out what the problem is.
-Olivia
Just installed a kitchen faucet Moen CA87316SRS and there's hardly any water pressure when I open tap. Is there an adjustment I can make somewhere?
no adjustment make sure your water shut off valves are fully open and the hoses or pipes are not kinked.
Top Microwave Ovens Experts
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
john h
Are you a Microwave Oven Expert? Answer questions, earn points and help others
