Canon PowerShot A590 IS Digital Camera Logo
Anonymous Posted on Feb 05, 2011
I have to reset date time etc everytime i turn camera on
Andy
Level 1:
  • Contributor 262 Answers
  • Posted on Feb 05, 2011
Andy
Contributor
Level 1:
Answers
262
Questions
0
Helped
60044
Points
28
If the Date/Time menu appears when the camera power is turned on, the date battery charge is low and the date and time settings have been lost. Please purchase a lithium coin battery (CR1220) and replace it as follows.
1. Confirm that the camera power is turned off.
2. Slide the memory card slot / battery cover lock and open the cover.
3. Hook your nail onto the date battery holder and lightly pull up.
4. Remove the battery holder in the direction indicated by the arrow. I have to reset date - a570isbackupbatremove.gif 5. Remove the battery by pulling it up in the direction indicated by the arrow.
6. Insert a new battery with the (-) side facing up.
7. Replace the battery holder and close the memory card slot / battery cover.
8. When the Date/Time menu appears set the date and time.
  • Andy Feb 05, 2011
    I'm sorry, for some reason the images did not appear. Please check out these two:http://usa.canon.com/app/images/service_... A570IS/A570ISBackupbatremove.gifhttp://usa.canon.com/app/images/service_... A570IS/A570ISbackupbat.gif
    --- Andy the Chicken
  • Andy Feb 05, 2011
    I notice that Fixya has even screwed with the links... if you can't get to the images, note that the internal date battery is in a small slot just next to the regular batteries.
4 Related Answers
Anonymous
  • 3 Answers
  • Posted on Dec 28, 2008
SOURCE: date and time
When you open the battery compartment, there is a small round battery(under the cr1220) slot, lift up this slot and take the battery out and replace it, this is the battery for that function of the camera.
Anonymous
  • 477 Answers
  • Posted on Apr 20, 2008
SOURCE: Casio EXZ75 Camera
Your problem does not lye on any memory card. it is because the internal battery that helps the cmos "cameras internal memory" hold its settings has gone out and needs tobe replaced. all you need is 2 1.5 volt hearing aid batteries stacked and taped +-+- and soldiered in place of the old cmos battery. witch is located on the front side bottom close to the bottom left of the lens. and placed next to the speaker. get some small batteries to do this het smaller the better for placement location.Hope this helps I have done this to a few camera's and it works fine.
KingDWS
Dave King
  • 1606 Answers
  • Posted on Sep 12, 2009
SOURCE: everytime I turn the camera on the time and date
There are two batteries in the camera. One is the big one you charge and the other is a little coin type battery. This coin battery maintains your settings and when it goes your camera forgets things. Same setup on computers and a lot of other electronics. In your camera the battery is a CR1220 worth about $1-$2. It should last about 3-5 years but you never know.
The battery is in a little holder on the left hand side of the camera. Its under the same cover as the usb connector and power plug in. You should be able to pop out the battery holder fairly easily. This is one of those things that if you take the camera to a battery store they will probably do it for you if they aren't busy. If you look at page 137 of your manual you will find the instructions for doing it yourself.
Anonymous
  • Posted on Jul 15, 2010
SOURCE: every time I set the date/time on my camera and
Replace the date/time battery on the side of the camera.
Top Canon Cameras Experts
Grand Canyon Tech
Grand Canyon Tech
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Canon Camera Expert? Answer questions, earn points and help others
