Brother DCP-7040 Laser Printer Logo
Posted on Jan 24, 2011
Drum error - Brother DCP-7040 Laser Printer
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jul 26, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1432
Points
With the front cover still open press "clear/back." it will ask if you are replacing the drum unit. press the up arrow to indicate yes. wait till it says accepted and then close front cover
Anonymous
Level 1:
New Friend:
  • Contributor 7 Answers
  • Posted on Jan 24, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
7
Questions
0
Helped
4446
Points
21
Drums have a finite life on all laser printers. The 7040 has a drum life of 12,000 pages. This is a firmware setting built into the printer. The error light comes on before you reach that limit to give you time to replace it before the printer stops.
Replacing the drum is fairly easy. I would recommend Amazon.com as a good source of finding an inexpensive drum replacement for this printer. I have a brother 2170, and ordering a replacement drum through Amazon and saved a good bit over what I could have purchased it for locally.
You can reset the error light, and not replace the drum if all is printing fine. Open the front .door, remove your existing drum. Leaving the door open, put the original drum back in. Push the options button, and you will be asked "New Drum?" Select Yes and Accept, and the counter will reset. The error light should then go off.
Please show me how to reset drum error for Konica-minolta bizhub 20
Do you have an actual error or is the drum stating end of life?
If you have real error, error code will be needed.
If your drum is stating end of life, then check ebay for reset chips. These chips will reset your life counter.
But at some point , the drum will fail. Also no not shine strong light on drum and do not work on drum in front of sunny window, sunlight will kill drum.
How Do I Fix Brother Printer Drum Error?
Toll-Free +1-866-231-0111 Brother printer receiving the 'Drum error'? Then, you have to clean the corona wire on the drum unit of your printer immediately to resolve the issue. Brother Printer users often face this common error but before calling the company for an instant tech-support, trying some steps can help to resolve the issue. Have you been facing the issue for quite some time and keep asking yourself How to Fix Brother Printer Drum Error? Then we here have some solutions for you. Follow the given steps and DIY resolving the error and see whether it's gone or not.
Step 1 Fix Brother Printer Error Drum
· Slowly open the lid of the printer and remove the drum unit
· Also, remove the toner cartridge assembly
· Keep a piece of paper on which the parts can be kept to avoid spilling of the toner
Step 2 Brother Printer Error Drum
·If the error Drum still persists, you have to replace the drum assembly.
·Consider resetting the Drum Counter
·Press the 'Menu' option> click on the 'Machine Info'> now click on 'Reset'
·Press Ok
·Now Press 1 to reset the drum unit counter
·Press Stop or Exit when
Brother Printer Customer Care Number +1-866-231-0111
If the mistake occurs, call for instant assistance at the Brother Printer Customer Care Number +1-866-231-0111. We are a 24 * 7 group of well-qualified and experienced engineers. We are willing to help you with your toughest printing mistake. Our techies strive to provide analyzed responses to all inquiries linked to the client
Ricoh 5002sp error add toner and sc396
Drum motor error;
The machine detects a lock signal error from the drum motor for 2 seconds after the drum motor turned on.
  • Overload on the motor
  • Defective drum motor
  • Defective harness
  • Defective IOB
Try removing the drum and turning the gears.
3answers
How to reset Ricoh mpc2030 color copier sc491 error
you can't reset this error by software!!!
Most often there is a problem with charge leak in one of the drum units, or paper transfer unit. Try first with replacing most used PCU (maybe the Black one). If you have old and used drum unit try to use it again. Drum is the same for all colours. If you stop charge leaking, the error will dissapear after restart.
Pif
What is the cause of OKI C3200n fatal error 173
Fatal error code 173:
This error indicates that the Image Drum Up/Down Process is not working properly. The errors are as follows:
140 - Yellow Drum Up/Down error
141 - Magenta Drum Up/Down error
142 - Cyan Drum Up/Down error
Solution:
1. Reseat the Image Drums. Ensure they are in seating properly into the drum carriage.
2. Reseat the Toner Cartridges. Ensure they are seating properly into the Image Drums.
3. Reseat the Contact Sensor Spring assembly and inspect it for damage or mis-alignment. If the springs appear bent or dis-lodged reseat them.
Drum error dr-420
Sir/Madam
he following error messages will continue to appear if the drum counter was not reset when you replace the drum unit with a new one.
  • Replace Drum
  • Drum End Soon
  • Drum Near End
  • Drum Stop
To clear these error messages, you need to reset the drum counter,
Or Visit official Brother Printer website For Brother Printer Troubleshooting Page Url Below:http://welcome.solutions.brother.com/BSC/public/us/us_ot/en/faq/faq/000000/002800/000037/faq002837_000.html?reg=us&prod=mfc7340_us_as&c=us_ot&lang=en
Or
Still Having Problem then follow Us On For
Brother Printer Support
I HAVE C5500 OKI PRINTER AND THE ERROR SAYS REPLACE IMAGE DRUM 561:M DRUM LIFE I PUT IN NEW MAGELN AND STILL HAS THAT MESSAGE
oki printer c5950 fix new cartridge & drum coming error replace image drum 561:m drum life
Falal error 173 on oki c5650 after changing fuser unit
Cause:
Resolution:
http://my.okidata.com/PP-C7200.nsf?opendatabase
2answers
Sc491 error on ricoh MPC 3500
Sc 491 straight from manual
High voltage power: Drum/ development bias output error
An error signal is detected for 0.2 seconds when charging the drum or
development.
 High voltage leak
 Broken harness
 Defective drum unit or development unit
 Defective high voltage supply unit
1. Check or replace the harness.
2. Replace the drum unit or paper transfer unit.
3. Replace the high voltage supply unit.
17helpful
3answers
Error code E000020-01b0, E000020-0260
E020 is a Drum/developer error code
-01b0 is a yellow drum error
-0260 is a magenta drum error
drums need replaced
7622A001AA Yellow drum part#
7623A001AA Magenta drum part#
7624A001AA Cyan drum part#
7623A001AA Black drum part#
Norman Weimar
Norman Weimar
Sudeep Chatterjee
Sudeep Chatterjee
