Hoover U5721-900 WindTunnel Upright Vacuum Logo
Posted on Dec 19, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I switch the vacuum from floor to accessory suction
Roger Potts
Level 3:
  • Master 694 Answers
  • Posted on Dec 19, 2010
Roger Potts
Master
Level 3:
Answers
694
Questions
0
Helped
225412
Points
1873
It automatically switches over when you disconnect the hose from the power nozzle. No suction it getting to the power nozzle, so the suction is only through the attachments. If there is no suction through the hose, check for clogs in the hose and in the tank where the hose plugs in. Also, check the screen at the bottom of the tank. If there is a clog in the hose or tank, then there also will be no suction to the power nozzle.
Remove all clogs and you should get suction.
5 Related Answers
Anonymous
  • 389 Answers
  • Posted on Apr 21, 2009
SOURCE: There is no suction to the floor sweeper. The
Sounds like you have two separate problems here.  If the brush bar does not rotate, probably the belt is broken. This is easily replaced, but you need to be precise about which model you've got so you get the right belt.
Loss of suction is due either to a blockage or, quite often, to a split in the short length of clear plastic hose that leads back from the brush bar enclosure.  Repair is possible but replacement is better.
If you need more help, post here again.
ukvacfan
Ryan S
  • 328 Answers
  • Posted on May 08, 2009
SOURCE: floor attachment does not suction, no clog in the hose, hand held works when dettached from floor attachment
Have you checked the floor head? Use a pipe cleaner or twisted metal to carefully and gently see what's in there. It sounds like dirt or something has definately sealed up the main suction channel.
Anonymous
  • 576 Answers
  • Posted on Jan 25, 2010
SOURCE: my vacuum cleaner spins but has no suction when I
Check for a clog between the hose and the front opening.
mmcdaniel106
Marla McDaniel
  • 6 Answers
  • Posted on Oct 15, 2010
SOURCE: Need Kirby Generation 3 Vacuum cleaner manual.
If your brush roll is turning and your bag is not overly full, then the only other thing it can be is a clog where the bag connects to the vacuum. Turn the plastic part out away from vacuum and lift off to see if you have something clogging it. It would have to be something big, but not so big that it could not get past the fan. As a rule of thumb, KIRBY never clogs. I suspect that your belt is stretched out and your brush roll is not turning while on the carpet so the brush roll is just in the way rather than brushing your carpet to pick up dirt.
Anonymous
  • Posted on Feb 11, 2011
SOURCE: Proteam Pro force 1500xp Upright vacuum... When I
Just undo the screws on the front part of the switch assembly, carefully check all the leads to the switch. Mine slide off all the time as the switch is poorly designed and subject to damage when the darn thing tips over (easily!!!) new switches are about 7.50 USD.
Top Hoover Vacuums Experts
AskDyson
AskDyson
Sudeep Chatterjee
Sudeep Chatterjee
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
