Qca Spas Majestic Series Aruba Xl Hot Tub Logo
Daniel Posted on Dec 17, 2010
When my spa is on heat mode pump on Low Speed it will not heat up. It says FLO and flashes do I have an air lock ??? Just changed pump a month ago.
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 5 Answers
  • Posted on Dec 19, 2010
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
5
Questions
0
Helped
1395
Points
5
FLO is a common signal for insufficient water flow through the heater tube. Do you see the low speed pump working? If you do, then try removing your filters, if FLO goes away then replace your filters with new ones. If not, your flow switch may not be working. You could have a legitimate flow issue caused from a clog or air-lock though.
Top Qca Spas Pool & Spa Experts
Grand Canyon Tech
Grand Canyon Tech
john h
Are you a Qca Spas Pool and Spa Expert? Answer questions, earn points and help others
