Brother MFC 7840W Printer Logo
Posted on Dec 17, 2010
What is the host address for brother printer /fax/scanner when trying to setup scanner
3 Related Answers
Anonymous
  • 832 Answers
  • Posted on Oct 31, 2007
SOURCE: Installation problems
How do you connect the mfc to your computer/laptop? In case you use usb make sure that the cable isnt longer than 3m and it is connected directly to your comp/lap usb. Do NOT connect to a hub. This causes a prob with the scanner.
In case you have it installed within a network (RJ45) there is a guide which can be download from brother homepage of your country. It explains the settings and installing for the scanner and printer.
Anonymous
  • 154 Answers
  • Posted on Feb 12, 2009
SOURCE: HOW DO I SCAN?
Hi, normally, if you have installed the complete driver set, the easiest way is to run a program with scanning capability i.e. photoshop, or word. the software normally given with a scanner is a 'twain' which becomes linked to the photoshop program. If you have MS word (I'll use this as an exAmple ), ensure the scanner software is installed, the brother switched on and connected to the computer correctly click Insert select picture then scanner - (or it may say twain). At this point the Brother mini program - the 'twain' should start and then follow the scanner instructions and a scan of whAtever you have selected should be inserted into the word document. Bit of trivia - TWAIN stands for Tool With An Interesting Name - yup it really is!.
MUKHTAR
mukhtar21 shaikh
  • 2022 Answers
  • Posted on Mar 16, 2010
SOURCE: I have a brother MFC-7430 all-in-one - Fax won't work
Go to menu option and choose the option fax and set the parameter like auto receive or manual set the ring auto answer mode after certain ring. If it is in auto receiving mode it will receive the fax after the ring which you set. Make sure the phone wire which you insert in fax machine getting proper dial tone and getting out going calling facility.
Have a nice day and do not forget to rate please...!
Hope this helps. Please rate my response.
Thanks.
Norman Weimar
Norman Weimar
Sudeep Chatterjee
Sudeep Chatterjee
