Konica Minolta bizhub 350 All-In-One Laser Printer Logo
Pastory Zacharia Posted on Nov 30, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The machine has the error code c0500. I need to know how to reset the error
ONE-Touch-Solution
Level 3:
  • Konica Minolta Master 1,679 Answers
  • Posted on Nov 30, 2010
ONE-Touch-Solution
Level 3:
Answers
1679
Questions
Helped
413239
Points
5442
Code C-0510 means a low fuser temperature. Most probable cause for that - the fuser lamp is probably defective. Try first to clear the error code (if the lamp is close to its life's end the code may pop up after a long print) so do this: power machine off; turn on the machine with the stop key held down; turn off, then on again. If this doesn't fix it then you need a new fuser
Thank you for contacting FixYa
*Please rate this solution with Thumbs Up
Good Morning, my Konica Minolta 7220 is showing error C0500
Error code C0500 and C0501 means Fixing unit's temperature abnormality.
How to reset these codes?
To reset Error codes C0500 and C0501, perform the following steps.
1-Turn the machine "OFF".
2-Press the "STOP" button on the basic panel.
3-Keep the button pressed and turn the machine "ON".
4-Do not release the button, until the machine warm up.
5-After few seconds Error code will remove and machine will reset.Basic menu will show no error on LCD screen.This means error code has been removed and photocopier machine is ready to use.
http://servicekonicaminolta.blogspot.com/2012/03/error-code-c0500-and-c0501.html
HOW TO SOLVE ERROR CODE C0500 FOR KONICA MINOLTA 211
Reset c0500
1helpful
C0500
Code error c0500
Open the front door, to the upper left there is a small access remove the plate press the button with the machine on that will reset the c0500 code if it comes back do NOT reset the machine it is telling you that it need fixing continue to do that can destroy boards worse case start a fire. YOU are resetting the code for the Fusing Unit which fuse the toner to the paper. GETS very hot normally.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
ERORR C0500
3helpful
The machine di251f is saying contact your technician with code error c0500 please help
C0500: Warming-up Failure
error code c0500, checked lamp and thermo fuses, checked thermistor ok. reset machine
3helpful
2answers
Minolta error code c0500
A C0500 code deals with the fuser temp. You maybe able to reset the code, by pressing the trouble rest switch. If it will not clear you will need to look deeper into the fuser unit. I don't know what model you have, so I can not go any further. Good Luck
3helpful
Error code C0500
C500 is a fuser code, the hot part of the machine, the fuser fuses the toner to the paper, so that the toner does not smear off. But to solve this must have the model number. As each series of machine has a different way to reset machine
1helpful
2answers
Bizhub Di1610fp
C0500 code that is fuser.try reset this one first by powering machine on while holding down STOP BOTTON ON THE OP PANEL
hope that help
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
