Fender Rumble 100 Bass Guitar Amplifier Logo
Posted on Nov 26, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Input jack is broken - Fender Rumble 100 Bass Guitar Amplifier
Fred Yearian
Level 3:
  • Fender Master 5,603 Answers
  • Posted on Nov 27, 2010
Fred Yearian
Fender Master
Level 3:
Answers
5603
Questions
Helped
2303248
Points
16163
VERY common problem... this is why you ALWAYS loop your cable through the handle. One trip over a guitar cable and the yank sideways destroys the jack... AND the jacks are really weak and poor to start with... Take the thing in for repair, or if you are electronically adept replace the jack yourself. MOST of these have the jack soldered to a circuit board and one often has to remove all the front knobs and the nuts holding the volume controls and move the bord back to remove and replace the jack...
How to get to the input jack on a bugera 62/62 amp head.
Repairing the input jack on your Bugera 6262 amp head is a task that requires careful attention and technical expertise. If you're comfortable with electronics and have experience working with amplifiers, you can follow these general steps to access and repair the input jack. However, please note that working on high-voltage electronics can be dangerous, and if you're not confident in your abilities, it's best to seek professional assistance.
  1. Safety Precautions:
    • Disconnect the Power: Ensure that the amplifier is completely unplugged from the power source before you begin any work. This is crucial to prevent electric shock.
  2. Gather Tools:
    • You'll need a set of screwdrivers (Phillips and flat-head) appropriate for the screws used in the amplifier's casing.
    • A soldering iron and soldering supplies (solder, desoldering braid, etc.) for working on the input jack connections.
  3. Opening the Amp:
    • Remove the screws holding the amplifier's chassis in the enclosure. These screws are usually located on the rear panel or sometimes underneath the amp. Keep track of the screws and their locations.
  4. Accessing the Input Jack:
    • Once the chassis is removed from the enclosure, you should have access to the internal components of the amplifier. Look for the input jack and its connections on the PCB (printed circuit board).
  5. Repairing the Input Jack:
    • Carefully examine the input jack's connections. If you see any loose or broken solder joints, you'll need to re-solder them. Use a soldering iron to heat the solder joint and apply a small amount of new solder if necessary.
  6. Testing and Reassembly:
    • After repairing the input jack connections, it's a good idea to test the amp's functionality before fully reassembling it. Plug in your instrument and ensure that the input jack is working as expected.
  7. Reassembling the Amp:
    • Once you've confirmed that the input jack is functioning properly, carefully reassemble the amplifier. Make sure to secure all screws and components properly.
Jul 05, 2023 • AMP Music
Broken input
replace. hopefully its a simple plug and play so you just have to plug in the new input.
1helpful
Fender telecaster keeps cutting out
the input jack is either dirty=crackling sound in and out or broken or a wire has come off your input jack or is loose
Yamaha CP 300 broken headphone jack
Some keyboards use the amp output sockets for headphone use.
You might need some adapters for your headphones.
If it fell in, you would see an empty hole. This would be unlikely because it is held on by two screws. If all fails, buy an amp with a headphone jack input. Plug the keyboard into the amp and use the amps jack.
2answers
Input jack fell inside
Yes, the jack MAY actually be broken. It will need to be serviced. Run cables through the handle to avoid plugs from being yanked sideways and breaking the jacks.
Hello. I have a Boss MT-2 distortion pedal. It will not power up with the adapter or battery. Wondering what could be wrong. Any suggestions on what to look for? Thank you!
The battery is connected via plugging in the input guitar cable ( a seperate contact is made at the jack). Sometimes this can be broken. Usually this failure is caused by someone stepping on or yanking a cable and the solder is broken at the jack/board attachment. This can be the input jack OR the power jack. Occasionally the circuit board or the traces on it are cracked, requiring jumpers to be installed on the board. In any case, open the pedal and look for these problems.
Hi :) I have a problem with my Boss mt-2 pedal. Whenever I insert the jack plug in the input, the adapter switches off automatically. The pedal works fine with battery and no problem is created. This only...
Make sure you are NOT using a TRS (stereo or three conductor cable) type cable. PLugging into the input should turn the pedal ON, not off. The switch on the jack may be broken or soldering to the circuit board may be broken OR worst case, there is a crack in the circuit board.
I just bought a used valveking 100 half stack and the 1st channel does not work, second channel works but seems to have a loose input jack as connection is intermittent and affected by wiggling the input...
Same thing... they probably broke both jacks. Sometimes the guts of the jack is broken and it doesn't appear to be broken but is broken internally. You may find broken solder on the pins to these jacks as well.
Note that the two input jacks have a different gain.
Here is schematic: http://elektrotanya.com/peavey_valveking_100_212.pdf/download.html
The sound on my mg100hdfx cuts out sometimes then its fine what could this be
Common problems are broken or intermittent input jacks or cracked circuit board or soldering or broken volume controls. Another one is a bad switch contact on the jack for PA input connection. All these are internal and require servicing.
External problems are guitar and cable problems.
Input wires broken loose, not sure where the go to
The center pin is your tip..which should have a wire going from 1/4" jack to the XLR jack. Pin 1 is earth ground...should be coming from 1/4" jack sleeve. Pin 3 would come from the 1/4" jack ring.
http://upload.wikimedia.org/wikipedia/commons/thumb/8/81/XLR_pinouts.svg/540px-XLR_pinouts.svg.png
If you are still having trouble, post links to pictures of the internals of the guitar showing the assembly.
Mar 27, 2009 • Music
Top Fender Music Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Fender Music Expert? Answer questions, earn points and help others
