Hi Jerry
Here are the steps on replacing the harddrive in your system. It is pretty each just becareful of the static see warning below. Everything should go smooth for you.
ESD can permanently damage your computer and even kill it. Always ware ESD wrist strap when you work with internal computer components. And avoid static discharge.
Hope this helps answer your question.
Bill
test all leads that attach to your hard drive including electrical extensions SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty or just replace them they could be faulty
even something as small as an electrical extension or a faulty fan lead can cause you problems computer needs all of the data and power to travel through every working device and to have an end for a computer to be able work properly
a motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive check all electrical extensions make sure they are securely seated even the cd/dvd drives need to have current go through make sure these devices are working
check the cpu make sure it has dust free secure seating
also check your computer ram modules to make sure they are dust free and securely seated
hope this helps you
