Weiser Lock ED1460X3VKD Powerbolt 1000 Electronic Deadbolt Logo
TIM PENNER Posted on Sep 20, 2010
Hi, I bought a Weiser powerbolt 3000 lock and I can't get the remote to work. I checked the battery in the remote and it has a voltage of 3.2 volts. What is it supposed to be? Everything else works.
5 Related Answers
Anonymous
  • 26 Answers
  • Posted on Aug 18, 2009
SOURCE: my powerbolt keeps beeping short beeps and then
dead batteries
Anonymous
  • Posted on Jan 24, 2010
SOURCE: i have an old weiser powerbolt 3000 with a remote.
I have the Weiser Lock powerbolt 3000 Home Access system Model WLTX Garage door opener and the Battery is a Maxell CR2032 3 Volt. very common.
sonicboomele
sonic boom electronics
  • 1557 Answers
  • Posted on Aug 02, 2010
SOURCE: How do I reprogram the
  • Remove the inner cover plate from the lock.
  • Locate the small round reset button near the left side of the circuit board (Red or Black).
  • To program, press the reset button once, then enter your 4-8 digit code on the exterior keypad, then immediately press the middle lock button on the exterior keypad. You will hear a beep. This signals that your code has been accepted.
  • To enter a second code, follow the same procedures as in step 3, but this time press the reset button twice then enter your code.
best of luck.
Anonymous
  • 963 Answers
  • Posted on Mar 05, 2011
SOURCE: Touch pad does not work on weiser lock powerbolt.
I found this Frequently Asked Questions sheet for the Powerbolt 1000:
http://www.weiserlock.com/Support/Faq/50160000000HhhZAAS.aspx
I hope this helps.
Anonymous
  • 963 Answers
SOURCE: My lock, weiser lock Powerbolt, right now is
I think this link answers your question:
http://www.weiserlock.com/Support/Faq/50160000000HhmZAAS.aspx
I have installed your Powerbolt, but when I push the Lock Button, it unlocks? What should I do?
First remove the cover on the inside of the Powerbolt unit. On the right hand side under the batteries, you will notice that is says "Door Direction Jumper". If the cap is mounted on Prongs 1 & 2, carefully remove it and move it over so that it mounts Prongs 2 & 3. A is right handed, B is left handed
Top Weiser Lock Locks & Locksmithing Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Weiser Lock Lock and Locksmithing Expert? Answer questions, earn points and help others
