The most likely reason is that the map has become unselected.
If this doesn't solve the problem the maps may be locked.
To unlock the maps you'll need to register your satnav if you haven't already done so. To register connect your satnav to your computer and go to www.garmin.com Select your country and click MyGarmin. Then click Register Your Garmin Product. You'll have to create a username and password to register. Write them down and keep them safe as you'll need them again anytime you need to update your maps.
Retrieving your unlock codes:
Creating an unlock code file for PC:
Creating an unlock code file for Mac:
If you have only one map on your satnav you will need then to select it as described in paragraph 1 above.
If you have a second map on your satnav e.g. if the main map is USA and you have bought a second one of e.g. Europe which also needs to be unlocked;
When you have unlocked all maps you will then need to select them as described in Paragraph 1 above.
