Dehumidifiers Logo
Posted on Apr 11, 2008
We lost the directions for our Danby dehumidifier. The model number is DDR557HE. Serial. No. 0107050701350. Can you help me out. T. MacKay
  • winniw Jul 28, 2008
    Recently purchased a Danby DDR557HE Dehumidifier...however there were no instructions as how to set the controls......
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jul 12, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1400
Points
5
I had the same problem but was able to find a link from "Danby's" website. Hope it helps!!
http://www.danby.ca/cms/uploads/products/en_manual/DDR557HE.PDF
Anonymous
Level 1:
  • Posted on Oct 19, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1400
Points
Post a DDR557HE PDF manuel on Danby site.
How do u operate Danny dehumidifier model DDR607EE I don’t have a manual for it
I found a PDF of the owner's manual for the Danby DDR607EE at Reliable Parts, http://www.reliablepartsinc.com/danby/dehumidifiers/DDR%27S/DDR607EE/ . The direct link to the manual is http://www.reliablepartsinc.com/danby/dehumidifiers/DDR'S/DDR607EE/OWNERS%20MANUAL.pdf . However, before you use this dehumidifier, go to https://www.recallrtr.com/dehumidifier . Use the drop-down menus to select Danby and the model. Then enter the serial number and make sure that this unit doesn't have the manufacturing flaw that could cause a fire.
I hope this helps.
We have a dandy dehumidifier ddr557he and have lost the manual. How do We get one online
I FOUND SEVERAL PLACES TO GET ANSWERS TO THIS QUESTION(S)
1. I LOGGED INTO DANBY.COM AND THERE IS A FAQ SECTION, YOU CAN DO THIS AS WELL.
2. FOR THE MANUAL I COULD LOCATE IT AT MANUALSDRIVE.COM
THEY HAVE YOUR SPECIFIC MANUAL.
My dehumidifier ddr557he will no longer defrost. How do I repair this?
well there are three things i know of that can cause this :
1st your filters are dirty needs cleaning .
2nd your humistat is set too low , unit runs too long with out a cool down period , 70% rh is a "normal" setting
3rd in older units that might be getting up there in years its possible that some of the cooling gas has leaked out and this causes freeze ups
Need manual for danby Model # DDR557HE Seial # 0107040706556
Here is a link to a generic Danby user's manual which should help out since they all use the same basic controls:
http://www.danby.com/cms/uploads/products/en_manual/DDR5009,_6009,_7009REE_EFOM.pdf
To view the Owner's Manual with Operating Instructions just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information at the website indicated and the contents of the Owner's Manual.
You may need ADOBE READER installed on your computer to read PDF documents.
You can download this free at WWW.ADOBE.COM if necessary.
Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there, then follow the onscreen instructions to install the software on your computer.
I hope that was helpful to you, good luck and take care.
Joe.
3helpful
2answers
I need a manuel for the danby dehumidifier model #DDR557HE. I dont know what the symbols mean
Unfortunately, the model number you listed has been discontinued. But is still supported thru the Danby Consumer help line: 800-263-2629. Contact them regarding your need for the Owner's Manual and they can email you one as an attachment.
I hope this helped you, Susan. Thanks for choosing FixYa.
I would like to have a munual book for my dehumidifier DDR557HE. A french version would be very appreciate but I could use an English one also.
I wish I spoke more than a few words of French. Never the less, the following link in French, is where you can find it. Search for the model number of your unit and from there (if it pops up. They don't always do) go to that page. If it doesn't click on Dehumidifiers and look for the one you have. Click on it, and when the next page opens, click on Support. The Owner's Manual in French can then be downloaded & printed for future reference.
I hope this helped you and thanks for choosing FixYa.
1helpful
We have Danby Model DDR557HE-7 and cannot locate our Manual. We need to disconnect hose and have excess water go to bucket. How is this done?? If we had copy of Manual we wld be able to search same...
All Danby dehumidifiers, regardless of the model number operate the same way.
The link below to a 50 pint model should provide all the info you need.
http://www.danby.ca/cms/uploads/products/en_manual/DDR5009%2C_6009%2C_7009REE_EFOM.pdf
However, I think you'll find that draining into a bucket is not an option. As the hose drain relies entirely on gravity to drain. So, it will not drain down and then up into a bucket. The hose drainage method, is designed to drain into a floor drain or a sump.
Hope this helps you.
2answers
Looking for manual for DDR557HE
The Model Number you listed is either incorrect or has been discontinued. As it does not show up in my data base for Danby. Please check the number again and advise.
Thanks.
3helpful
Danby Dehumidifier DDR557HE has never dehumidified
either lacks coolant or compressor bad
Top Danby Dehumidifiers Experts
ADMIN Andrew
ADMIN Andrew
Don A
Don A
Anonymous
Are you a Danby Dehumidifier Expert? Answer questions, earn points and help others
