Canon PC-920 Black and White Copier Logo
Posted on Jan 10, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Error code 5100
Canon mp460 error code 5100
Anonymous
Level 3:
President:
  • Master 4,402 Answers
  • Posted on Jan 10, 2008
Anonymous
Master
Level 3:
President:
Answers
4402
Questions
0
Helped
1734573
Points
8129
2answers
What does 5100 code mean?
What is error code 5100 on the MP460? - Canon Community
community.usa.canon.com/t5/Personal.../What...code-5100.../103212
Jul 7, 2014 - Please remove foreign objects so that the print head holder can move: ... closet and hooked it up this morning, I was getting the 5100 message.
How to resolve error 5100 on an MX452 / MX459 - Canon
https://support.usa.canon.com/kb/index?page=content&id...
There are several reasons for error 5100 to appear. ... If the above recommendations donot help you resolve the error, the printer will need to be repaired.
How To Fix Canon Printer Error 5100 - YouTube
? 2:23
https://www.youtube.com/watch?v=rJQVwwRxPv4
Mar 14, 2013 - Uploaded by ITJungles
Learn how to fix the Canon printer error 5100, and have your printer running again. ... Reset error Canon ...
2answers
Error 5100 cannon mp460
The root cause of Error 5100 in Canon inkjet printers can be so varied and so the solutions. If you want to read a best and well researched article on this topic, read it here:
Canon Error 5100
7helpful
5100 is a Carriage Home Position Error. try cleaning the plastic strip that runs the length of the carriage, it may be contaminated. Use alcohol and a swab Good luck. Thanks for using FixYa.
2answers
Canon error 5100 cartrige jumped
I think you are seeing "ERROR 5100: Cartridge Jammed", right?. Here is the most likely solution to this issue with your printer. The following procedure comes directly form Canon
ERROR LCD: CARTRIDGE JAMMED
1. Press ON/OFF switch to reset the multifunction device 2. Removing obstructions, foreign objects and paper jams MP750 / MP780 3. Reseat MP750 / MP780 print head 4. The MP780 may require repair
4helpful
Error message on Canon MP160 flashing E-2-2 error message 5100
The error code refers to Ink Cartridge
Issue: ERROR: Error code 5100 appears on the computer screen
Issue: ERROR LED: E, 2, 2
1. Disconnect and reconnect power cord to reset the device
2. Remove Packing Material MP160 / MP180 / MP460
3. Reseat ink cartridge (MP160 / MP180 / MP460)
Canon mp460
  1. On the operator panel, press and hold the <ON/OFF> button for one second. (The display will go blank.)
    Note: It may be necessary to unplug the power cord if pressing the ON/OFF button does not shut off the printer.
  2. Wait approximately ten seconds and then press the <ON/OFF> button again.
  3. Wait until the device has completed its cycling process before submitting another job request.
If that does not solve it, make sure it is powered on remove the ink cartridges individually then replace them this should resolve the problem.
Error code 5100
This might help: http://www.fixyourownprinter.com/forums/laser/25975, they had the same problem
Error code 5100 - can't clear it
Lift up below the display screen.The printer top will raise up and a arm will lock into place.Make sure the ink cartriages are firmly in place,snaped into position,sitting flat.Lift arm out of the way and close the lid.Worked for me ,good luck.
3answers
Canon mp460
Dear thechad,
go to the canon website (listed below) - under Tech Support - click on Technical FAQ's (this will pop up another small window)
then click on Search by Key Word
next - type in error 5100 and click on the circle next to - Include all words and hit Search
next - click on the link with your answer "how to.... "
this should show the answer
http://www.usa.canon.com/consumer/contro...
Cheerup
Grand Canyon Tech
Grand Canyon Tech
Sudeep Chatterjee
Sudeep Chatterjee
