Measuring Tools & Sensors Logo
G
Gayle winger Posted on Feb 27, 2019
Need outside temperature senor for sio/scan clock model88909
5 Related Answers
jerryg50
Jerry Greenberg
  • 1691 Answers
  • Posted on Apr 21, 2008
SOURCE: Out side temperature reading
Without having parts to try, this would be difficult to know what the fault is. Inside this unit there is a circuit board, and on the outside there is the exernal temperature sensor.
There are only a few things that can go wrong. There is not much that is servicable unless you can find a spare board, or a spare temperture probe. There is very little posiblity that in any practicality this unit can be serviced at the component level.
I would just go out and buy a new unit.
Jerry G.
Anonymous
  • Posted on Feb 11, 2010
SOURCE: I have a Sio Scan Atomic Clock cannot get the
found instructions fixed problem, thank you
Anonymous
  • Posted on Mar 14, 2010
SOURCE: Need instruction for setting clock model # 38229-1
Setting timezone: Enter alarm time preview, by pressing "Mode". Press "Adjust" to change time zone.
Setting time: When previewing time, press and hold "Alarm on/off" Until time blinks. Press "Adjust" to change time; Press "Alarm on/off" to change to minutes, ect. Press "Mode" when done.
Anonymous
  • Posted on Apr 24, 2010
SOURCE: Sio/Scan Temperature Transmitter 433MHz for batteries
I just changed the batteries yesterday. It was hard to open the battery compartment with bare hands/finders. I used flat screw driver to poke into the notch in the center of the transmitter. Or you can try poke into any **** around the compartment. It works!
Anonymous
  • 5 Answers
  • Posted on Jun 29, 2010
SOURCE: We replaced the batteries on our SIO SCAN temp
Take the batteries out of the clock AND the temp transmitter. Wait about a minute, then replace the clock batteries. Wait another minute, then replace the transmitter batteries. Once the clock synchronizes with the satellite, you will need to set the time zone and whether you want DST on or off.
Top Measuring Tools & Sensors Experts
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
