Sewing Machines Logo
A
Amelia Reynolds Posted on Jul 01, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I am getting a error code 13 on my singer future XL 550 machine. how do I fix it
R.A. Ellis
Level 3:
  • Singer Master 12,731 Answers
  • Posted on Jul 01, 2018
R.A. Ellis
Singer Master
Level 3:
Answers
12731
Questions
Helped
2712814
Points
59178
Am unable to find a reference to Error 13 for your machine so it may be something that needs to be addressed by a technician. You can try Singer Support:
http://futura-support.com/customer-support
You may want to download and keep the service manual for future reference:
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=2&ved=0ahUKEwiE8JzG1v7bAhWIyoMKHS9wDEcQFgg0MAE&url=http%3A%2F%2Fvideos.jennys-sewing-studio.com%2Fmain.php%3Fg2_view%3Dcore.DownloadItem%26g2_itemId%3D16556&usg=AOvVaw1l88iiIkvgUHnhZxX5W_kn
5 Related Answers
teddibear10
  • 35 Answers
  • Posted on Dec 08, 2013
SOURCE: My singer futures XL 400 won't sew underneat
If the stitch problem is on top, it is a bobbin problem, and if it is on the bottom, then it is a problem with the top.
Try rethreading your machine completely. Make sure that the tension is set correctly.
If rethreading doesn't work, then try adjusting your tension, a little at a time, till you can find something that works.
If none of the above works, try changing your needle to a fresh one. And do your sample stitching on a medium weight fabric. Very sheer fabrics can be problematic without sewing machine problems. Good luck with your machine!
99rannellis
R.A. Ellis
  • 12731 Answers
  • Posted on Aug 10, 2015
SOURCE: I just got my singer future XL 580. I embroidered several patterns out but now the under side is bird nesting. What seems to be the problem.
If it is bird nesting, most likely your upper tension is off. First, make sure that when you thread the upper thread that you FIRST RAISE THE PRESSER FOOT. That allows the thread to seat properly in the tension disks. Test your machine. If it is still happening, then you probably need to tighten the upper tension. The re-test and adjust until the upper and bobbin threads are meeting where they should.
Oh, yeah, one more thing. Have you tried putting in a brand-new needle?
99rannellis
R.A. Ellis
  • 12731 Answers
  • Posted on Apr 27, 2017
SOURCE: Have an 06 error code on my embroidery 550 singer
Search for:
Make Model error code
99rannellis
R.A. Ellis
  • 12731 Answers
  • Posted on May 10, 2017
SOURCE: I took out the bobbin casing to clean it on my singer futura xl 550 and now I am battling to put it back correctly.
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=6&ved=0ahUKEwiJtNaBu-XTAhVpyVQKHcPAD60QFghEMAU&url=http%3A%2F%2Fwww.singerco.com%2Fuploads%2Fdownload%2Ff4b6aac72632ff4c7f351f5fd9cf408d5078eeaa.pdf&usg=AFQjCNHuaFADnpJsju0lUUo9i46QWE7kbw&cad=rja (pg 14-15)
Testimonial: "I've already got the manual. I need a photo of bobbin in casing to see if I put it back correctly"
99rannellis
R.A. Ellis
  • 12731 Answers
  • Posted on Sep 05, 2017
SOURCE: teraz wyswietla sie blad nr 13 singer futura xl 580, wszystko jest czyste, hafciarka dziala, a jak wlacza sie maszyne wyskakuje error 13
Search:
Singer Futura XL 580 error 13
Top Singer Sewing Machines Experts
Rommel Balcita
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
