Microwave Ovens Logo
S
Susan Baker Posted on Jun 25, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do you set the time on this microwave - Microwave Ovens
  • devsharrma90 Jun 02, 2026
    To set the time on most Microwave Oven models, press the Clock or Time button, enter the correct time using the number pad, and then press Clock, Start, or Enter to save it.
    The exact steps may vary by model, so check the user manual if needed. If your microwave is old or difficult to use, you can easily purchase a new microwave oven from Ubuy for updated features and convenience.https://www.u-buy.jp/en/category/kitchen...
Rohit Itware
Level 1:
  • Contributor 2 Answers
  • Posted on Apr 15, 2025
Rohit Itware
Contributor
Level 1:
Answers
Questions
0
Helped
39
Points
6
Method 1: Clock Button
Press the “Clock” or “Time” button.
Enter the time using the number pad (e.g., 1 2 3 0 for 12:30).
Press “Clock” or “Start” to confirm.
?? Method 2: Power + Clock Combo
Press and hold the “Power” or “Clock” button for a few seconds.
When the display starts blinking, enter the time.
Press “Start” or “Clock” again to confirm.
  • Rohit Itware
    Rohit Itware Apr 15, 2025
ADMIN Andrew
Level 3:
Top Expert:
  • Microwave Ovens Master 73,781 Answers
ADMIN Andrew
Level 3:
Top Expert:
Answers
73781
Questions
Helped
6295750
Points
431340
How to set the clock on a Microwave Oven.
  1. With the oven Not cooking, press the [Clock/Timer] or [Clock/Timer (Less)] button twice. The colon : will blink.
  2. Enter time of day using the Number keypad.
  3. Press the [Clock/Timer] or [Clock/Timer (Less) button to finish setting and the colon : will stop blinking.
ADMIN Eric
Level 3:
Top Expert:
  • Microwave Ovens Master 42,220 Answers
  • Posted on Apr 09, 2025
ADMIN Eric
Level 3:
Top Expert:
Answers
42220
Questions
0
Helped
1142262
Points
683303
Make and model would give a clue as to the methos.
Frigidaire counter top microwave clock setting instructions I need to reset the time
In a question like this we need FULL 'make model (what it is).
Frigidaire Microwave Oven CFCM1134 Manual
Concord Pacific
https://www.concordpacific.com > 2018/03 > Fri...
PDF The microwave will start after 1 second delay. Setting the timer. 1. Use the number pads to enter desired heating time (cook time may be set up to. 99 minutes ...
21 pages
How do I reset the clock on gallery collection microwave
JustAnswer
https://www.justanswer.com > Appliance Repair
Mar 8, 2020 - 1. Tap (don't hold) the Clock & Settings button. Press it again several times until you say 12:00 ENTER TIME on the screen.
1 answer · Top answer: It may show a different number and that's fine. Once it has a number "for example" 8:46 ENTER ...
How do you reset the clock on a Frigidaire microwave?
Home Alliance
https://homealliance.com > Question & Answers
To reset the clock on a Frigidaire microwave, follow these steps: 1. Press the "Clock" button on the microwave's control panel.
How do i unset the time on my microwave
You could just unplug it but some microwaves, you have to have the time set before it will work.
2answers
Magic chef microwave runs backwards with door closed and no time set - works normally when time is set and door is closed - any ideas?
Probably a bad door switch or door switch mount. See help file here.
It's normal for a microwave turntable to run either direction at random. That's common in such AC motors.
Microwave Settings
look for the clock or watch symbol on the keypad. When you press it, it will show you a 12 hour(normal time) or 24 hour(army time indication).Select the correct time by pushing the hour then minute buttons. Once that is done, press the clock symbol again whick accepts the setting.
I have a 15 year old Toshiba microwave which I may need to replace. It can be set to cook in single seconds (eg for 23 or 38 seconds) a facility I find essential. Many new microwaves it seems can only be...
I believe the dial on Hobart microwaves allows you to manually enter any amount of time by spinning the dial for the desired time, and programmable buttons to save the time settings. HL1600 is 1.5 cubic foot, 44 liters
20helpful
4answers
How to set clock on sharp microwave
normally you look for the clock ot watch icon. Pressing it once will give you the option for 24 hours setting. Press it twice and it will give you the opportunity to set to 12 hours setting. Using the no. keypad, punch in the time and then repress the clock icon again.
I NEED THE INSTRUCTIONS ON HOW TO SET THE CLOCK ON MY MICROWAVE
To set the time just press CLOCK, then press CANCEL, then enter new time setting and press CLOCK again.
19helpful
3answers
Westinghouse microwave WST3502..... Problem:
Press "Clock", type in the time on the keypad and then press "Start". The clock runs a little slow (at least on mine) and I have to reset it about once a month. It gets about 10 - 15 minutes behind after awhile.
Top Microwave Ovens Experts
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
john h
Are you a Microwave Oven Expert? Answer questions, earn points and help others
