Computers & Internet Logo
J
James Murphy Posted on Jul 09, 2017
I have a teac pvr hdr2250 t how do you extend the recording time past 30 mins I want to record say 3 hours at one time
I used to have a top field pvr no problem doing this,but I'm told you can't get one anymore as business has been taken over
5 Related Answers
larry james
Larry Stiles
  • 301 Answers
  • Posted on Sep 18, 2007
SOURCE: audio dropout
take it or ship it to video tech service. they will clear it and go from there. it may need some tension adustments in addition. The guy there is super cool.
deepsuva
  • Posted on Apr 30, 2008
SOURCE: extended recorder
how can i REINSTAL MY N72 NOKIA SOFTWARE
Anonymous
  • Posted on Sep 06, 2009
SOURCE: I have purchased a Teac HDR2500T video recorder. I
The part re the other channels having no signal....I had the same problem with mine and that was because the small loop cable in the back wasnt right. I could watch all channels, press record and still watch that channel but try to watch a diff channel while its recording and they were gone. As soon as I had the loop cable in properly it solved the problem. Hope this helps....
Fred Yearian
  • 5603 Answers
  • Posted on Jan 09, 2010
SOURCE: my teac rw-d200 won't record on any new cd's
Sorry, but the "music" CD's are the only ones the unit can use.
This was an early attempt at keeping people from pirating audio discs of copyrighted music.
Staples has the music CD's:
http://www.staples.com/office/supplies/StaplesSearch?searchkey=music+cd&storeId=10001&catalogId=10051&langId=-1&fromUrl=home
Anonymous
  • 9 Answers
  • Posted on Jun 08, 2010
SOURCE: TEAC model A1500 tape recorder
What i did to solve this problem on my A-1500 was to remove the tension arm, the pinch roller and the front face holding screws , pull off the rubber faces from the reel hubs and remove them, remove the front metal face plate... in back remove the wood backing panel... inside the deck rear, remove, (without letting them fall into the mechanism) 4 screws that anchor the heavy front cast piece that holds the capstan flywheel...carefully lift the cast piece that holds the flywheel. away from the deck face just enough to allow the old belt be removed, and the new one installed...ensure the belt is installed and goes all around the flywheel..and is not pinched when you push the casting back against the deck face and reinstall the 4 rear anchor screws. place the belt around the upper drive motor pulley wheel.. small diameter part on motor pulley and large diameter part on flywheel for users of 60 hz. Ensure 60hz is selected on switch..or 50hz if that is what you need.(for 50hz ensure belt is on large motor pulley part and smaller flywheel diameter part. with deck lying down or leaning, place a few drops of light lube oil into the felt at the bearing hole for the flywheel. Give the deck a test playback before completely reassembling and putting all the parts back where they were.
Top Teac Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
john h
Are you a Teac Computer and Internet Expert? Answer questions, earn points and help others
