Retail Supplies Logo
N
Nirupa Devi Lal Posted on Jun 08, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need to know why the receipt is very light when printed
Electroboy
Level 3:
  • Retail Supplies Master 1,888 Answers
  • Posted on Jun 16, 2017
Electroboy
Level 3:
Answers
1888
Questions
Helped
691556
Points
3733
If it is an ink printer, the ink ribbon or roller is probably running out of ink. Buy a new roller or ribbon and try it.
If it is a thermal printer, the paper rolls may be low grade. Try buying thicker high grade paper rolls. If that doesn't work, the print head in the printer probably needs replacing.
Check your manual to see which type you have. If you need a manual, try these guys https://the-checkout-tech.com/cashregisters.php
I get an error blinking 3 lights on my tm88v printer and it only prints partial receipts
Please check the troubleshooting section of the manual to determine the fix for the blinking lights. This could also fix the problem of the partial receipts. If this does not work, then you might need to factor reset your receipt printer. Thank you.
1helpful
Hi the receipt will not print out but the journal is fine, do you know i can fix it?
Have you checked to see if the paper is in the correct way round, most tills have a receipt turn off mode. Consult your manual to find out how to switch back on
9helpful
We just got a new xe-a102, we do not need to print receipts...how do you turn off that function?
To disable receipt printing:
  • Press the Rcpt/PO key in the OP X/Z position. This key toggles the receipt printing status ON andOFF.
  • To check the receipt printing status, turn the mode switch to the OP X/Z position or press the CL key in the REG mode.
  • When the function is in the OFF mode, the receipt off indicator “_” illuminates.
To issue a receipt when receipt ON/OFF function is set to OFF:
If your customer wants a receipt after you finalized a transaction with the receipt ON/OFF function in the OFF
mode, press the RCPT/PO key. This will produce a receipt. If more than 50 items were entered, the receipt will be
issued in a summary receipt format. Your register can also print a copy receipt when the receipt ON/OFF
function is in the “ON” status.
8helpful
How do i get it to stop printing customer receipts
The following is the process to stop customer receipt printing. It will also describe how to print an individual receipt on demand. Best of luck and thank you for using Fixya! Kindly return to rate this solution.
Greg
Receipt ON/OFF function
You can disable receipt printing in the REG mode to save paper using the receipt ON/OFF function. To disable
receipt printing, press the Rkey in the OP X/Z position. This key toggles the receipt printing status ON and
OFF.
To check the receipt printing status, turn the mode switch to the OP X/Z position or press the lkey in the REG
mode. When the function is in the OFF mode, the receipt off indicator “_” illuminates.
The register will print reports regardless of the receipt state, so the paper roll must be installed.
"To issue a receipt when receipt ON/OFF function is set to OFF:
mode, press the Rkey. This will produce a receipt. If more than 50 items were entered, the receipt will be
function is in the “ON” status."
2answers
Receipt won't print after paper change (and it IS thermal...)
not knowing what the model is I suspect the machine suffered a power surge or got a spill
2helpful
Change on/off receipt function to off
The following is the method to turn the receipt printing on/off:
OFF.
All the best!
Greg
OKI 24DX - Press ONLINE button to print each page
you have to open your printer icon in CONTROL PANEL
CONTROL PANEL
THEN
PRINTERS AND FAXES
RIGHT CLICK ON YOUR OKI PRINTER
select PREFERENCES
under SET UP and MEDIA size change it to A4
I think this might help you. I'm guessing that you have the wrong size paper selected. And each time the computer needs you to confirm you want to print with a different size paper
I wouldn't phone OKI help line..I was on hold for 15 minutes, then just gave up.
Epson TM-U220D Receipt Printing Problem
mau download driver epson tm-u220d ga ada...
klo mau cari dimana yah
Casio TK2300 - receipt printing
Hi. It sounds like you have the receipt switch in the on mode. You'll probably find it can only do two receipts when they are called up when in receipt off mode, so slide the switch to off, then make a sale. at the end of the sale, press the receipt button once. Wait for print, then press it again. you can program it for a third if needed by doing the procedure I gave you, but use a 3 in place of the 2.
Mark
Top Retail Supplies Experts
ADMIN Andrew
ADMIN Andrew
Ngoro
Are you a Retail Supply Expert? Answer questions, earn points and help others
