Sharp XE-A404 PC Desktop Logo
Posted on Aug 01, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Change on/off receipt function to off - Sharp XE-A404 PC Desktop
Anonymous
Level 3:
  • Master 1,959 Answers
  • Posted on Aug 01, 2009
Anonymous
Master
Level 3:
Answers
1959
Questions
Helped
1240865
Points
7500
The following is the method to turn the receipt printing on/off:
Receipt ON/OFF function
You can disable receipt printing in the REG mode to save paper using the receipt ON/OFF function. To disable
receipt printing, press the Rkey in the OP X/Z position. This key toggles the receipt printing status ON and
OFF.
To check the receipt printing status, turn the mode switch to the OP X/Z position or press the lkey in the REG
mode. When the function is in the OFF mode, the receipt off indicator “_” illuminates.
The register will print reports regardless of the receipt state, so the paper roll must be installed.
To issue a receipt when receipt ON/OFF function is set to OFF:
If your customer wants a receipt after you finalized a transaction with the receipt ON/OFF function in the OFF
mode, press the Rkey. This will produce a receipt. If more than 50 items were entered, the receipt will be
issued in a summary receipt format. Your register can also print a copy receipt when the receipt ON/OFF
function is in the “ON” status.
All the best!
Greg
  • Anonymous Aug 02, 2009
    Please rate the solution you've been provided. Thank you.
Turn off receipt function
use the save paper button it will not print the receipt.
2helpful
4answers
Casio pcr-t2000A - programming receipt massage/logo Hello, I've purchased this cash register and am having hard time trying to put the company's name on the receipt. I strictly follow the instructions...
That just turns the logo on or off. If there is an old logo there, you don't need to do the 2122 command.
to change the name on most Casio machines:
Turn key to Program mode 2 SUBTOTAL 132 SUBTOTAL Now type the characters for the first line of the receipt using the alphabet on the edge of the buttons. If someone has removed the letters from the keys, just find the alphbet layout in your manual. 00 (double zero button) CASH (maybe labelled CA/AT) 232 SUBTOTAL Now type characters for second line 00 CASH 332 SUBTOTAL Now type characters for third line 00 CASH 432 SUBTOTAL Now type characters for fourth line 00 CASH SUBTOTAL
NOTE: You might have to do 2 receipt prints in REG mode to see the changes
If anyone is looking for / needs a Casio PCR-T2000 manual,
http://the-checkout-tech.com/manuals/cashregisters/Casio2.php
Print payment receipt
Go to customer and use the sales receipt function.
www.cpahispano.com
9helpful
We just got a new xe-a102, we do not need to print receipts...how do you turn off that function?
To disable receipt printing:
  • Press the Rcpt/PO key in the OP X/Z position. This key toggles the receipt printing status ON andOFF.
  • To check the receipt printing status, turn the mode switch to the OP X/Z position or press the CL key in the REG mode.
  • When the function is in the OFF mode, the receipt off indicator “_” illuminates.
mode, press the RCPT/PO key. This will produce a receipt. If more than 50 items were entered, the receipt will be
8helpful
How do i get it to stop printing customer receipts
The following is the process to stop customer receipt printing. It will also describe how to print an individual receipt on demand. Best of luck and thank you for using Fixya! Kindly return to rate this solution.
Greg
OFF.
"To issue a receipt when receipt ON/OFF function is set to OFF:
function is in the “ON” status."
My credit card receipts do not cut between the portion that the customer must sign, and the sales receipt portion. I'm forced to cut it manually. Has anyone else had this problem? Is there an option to...
In windows you have to set the printer to receipt printer and where you want it to cut the tape also check under setup or settings in pc charge then printers and then receipt printer there are functions you can change there as well.
www.greenlightpayments.com
SMS text receipts
In Nokia you can turn off receipts. You may need to get the manual out, but you do not have to have receipts, obviously a little money making scheme, like my voicemail access msgs costs me everytime!!!
Receipt not printing
I believe this might help, not exactly familiar with this exact model but here it goes.
When you use the printer to issue receipts, you can disable receipt printing in the REG mode to save paper
using the receipt ON/OFF function. To disable receipt printing, press the Rkey in the OP X/Z position. This
key toggles the receipt printing status ON and OFF.
If your customer wants a receipt after you finalized a transaction with the receipt ON/OFF function being OFF
status, press the Rkey. This will produce a receipt. However, if more than 30 items were entered, the
receipt will be issued in a summary receipt.
Copy receipt
You can print a copy receipt by pressing the Rkey when the receipt ON/OFF function is in the “ON” status.
To realize this function, you must enable the function. Please refer to page 62 (Job code 63).
1helpful
CASIO 130CR
Without Clerk Function codes 4000 = receipt; 4100 = journal
With Clerk Function codes 4002 = receipt; 4102 = journal
Top Sharp Retail Supplies Experts
woodzowl307
Narseman
Norman Weimar
Norman Weimar
Are you a Sharp Retail Supply Expert? Answer questions, earn points and help others
