When I go to print a document it does not print. instead it goes to a printer queue.
SOURCE: Computer Printing Problem
I'm assuming this is on a network printer.
1- try resetting the machine ( did not specify the model or make)
2- does it have the correct IP and gateway
3- try restting the PC and port
SOURCE: Print queue will not clear after printing
dear sir
this is a typical usb inkjet printer problem
just follow the steps
open notepad
and copy paste
net stop spooler
del %systemroot%\system32\spool\printers\*.shd
del %systemroot%\system32\spool\printers\*.spl
net start spooler
and save as delete.bat file on desktop
run this file and reboot the machine
and run this file again
now print queue will get cleared
thanks
SOURCE: document goes to the print queue, then errors
To start with You check the data cable is properly connected to your printer than you open the printer dialogue box and remove the documents pending in the queue and retstart the computer and before giving the print command select the printer that you are going to use(if more printers are connected to the computer).if all this does not work i suggest you to reinstall the printer after uninstalling it
SOURCE: Document won't delete from printer queue after printed
Have you tried to stop the spooler service in services?
Option 1)
Click on start orb
Type in search window:
services.msc
click ok
Scroll down to Print spooler service and click on it in the right side window.
On the left side click stop the service and wait forthe process to stop .Do not close the window yet. You will have to restart it here later.
next delete the print job in the printer queue then restart the spooler service
Resubmit your new print job.
Option 2)
If that doesn't clear it, the next step would be to stop the spooler
service as stated above
Go into windows explorer
(Print job data is collected and stored in a spool file in the spooler folder.)
It is located in:
C:\WINDOWS\system32\spool\PRINTERS
Your print job will show 2 files there Example below:
00002.SHD
00002.SPL
Delete the files located in there. There may be several of them depending apon how many print jobs you submitted. You will have to resubmit your print jobs all over again.
Next go back to services window and restart the spooler service
That will definitely fix it.
SOURCE: HP business inkjet 1100
This very simple solution works on my Business Inkjet 1100.
1) Turn the printer off, then back on, to clear the error.
2) Set your computer's clock back to a date prior to the cartridge expiry date.
3) Print something, (any documents will do).
4) Set your computer's clock forward to the correct date and the printer should still print, and ignore the expired cartridges.
My
1100 re-checks the cartridges and dates occasionally, but not frequently (it has
been about two months between checks) so you might need to repeat this
process every two months or so until you have used up your expired
cartridges.
This solution is much easier than dismantling the printer and changing/removing wires!
