Yes I agree that you should not have layed it down , please wait for 48 hrs now to run it again with unit in upright position
next id go over unit and look all all hose's seems a bit of mold builds up inside of these very often , Wight id always say to give it a little spritz of bleach water every 30-60 days or so to clean it out and keep your pipes flowing freely
one of those little bottles of compressed air for computer cleaning goes 4 miles to cleaning out little holes and such on these things
SOURCE: leaking water
It sounds as though the collection pail is not installed correctly, or the hose fitting cap is loose. Make sure that the pail is seated correctly & the cap is tight. Inspect the bottom for rust perforation, too, although this is a long shot. If this fails, then the cold coil may have broken away from it's mount, & is dripping in the wrong place. Inspection with the cover off will reveal any misalignment or broken components. Repair as required.
SOURCE: delonghi de400p
same thing happend to me. I wasnt sure if it was the settings or me. I unplugged it for awhile, read thru the instructions turned it back on setting it according to the instructions and it began to work again. Not sure if it had to do with the unit being off for awhile or I entered the correct settings. Im just happy it began to run again
SOURCE: Does not collect water (also 2 years old).
the evaporater coils rot out and the freon leaks out. thats about all the longer these newer ones last now.
SOURCE: simplicity 3-in-1 unit leaks water out of bottom when on humidify
Possible hose out of place?
