Dishwashers Logo
Terry Hall Posted on Jan 23, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What is error code c13 - Electrolux Dishwashers
Level 3:
Top Expert:
  • Electrolux Master 76,851 Answers
  • Posted on Jan 23, 2015
Electrolux Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
15380470
Points
237768
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
What is error code c13 - Electrolux Dishwashers EHT8ILG8 MODEL
Error code C13 on an Electrolux dishwasher model EHT8ILG8 indicates a problem with the water supply to the dishwasher. The code specifically refers to a problem with the water pressure, which could be caused by a clogged water inlet filter, a malfunctioning water inlet valve, or a problem with the water supply hose.
To troubleshoot this issue, first check the water supply hose to ensure that it is not kinked or clogged. Then, clean the water inlet filter and make sure that the water supply to the dishwasher is not restricted in any way. If the problem persists, it may be necessary to call a professional technician to diagnose and repair the dishwasher.
Please keep in mind that this is based on general information, the error code meaning may vary depending on the model and brand. It's recommended to check the dishwasher manual or contact the manufacturer's customer service for more specific information.
2helpful
How does C22 n C13 of F1 error code of suzuki burgman look like in picture
talk to a Suzuki service department and they will tell you exactly what sensors are affected by codes c22 and c13 and what replacements are necessary
Jun 25, 2013 • Motorcycles
Memory stick error C13:01 on DSC-P41
Try formatting the stick and try again, sounds like it is corrupted.
1helpful
2answers
C-13 read error
You forgot to say if it is a C13 read error or a C13 REC error.
Your owner's manual suggests that it is a problem with a dirty and/or crappy disc. Try a different, cleaner one.
Ac13 read error
C13 means the player or recorder cannot read the table of contents on the MD you inserted for some reason.
2answers
To whoever can help...I have a Sony, RCD W10. I am receiving 2 error codes when I proceed to record a cd. Error code C13 and C14. Does anyone know what this might mean? Simply frustrated
They are what you call fault codes. A fault code provides a machine-readable identifier that can be used to programmatically identify the error condition and respond as appropriate
2helpful
Sony minidisc MDS-JE530 c13 rec error
This could be a solution for your problem, if you get a C13 error it's because of dust on the lens causing TOC read errors. Try blowing out dust using clean compressed air (the kind in the can used for computer maintenance).
2answers
Not accepting disc message disc error c13
C13 is usually a motor error, but is dependent upon the model. Can you please post the model number and I'll look it up for you?
Thanks,
Dan
Disk error C13:01
Any C13 error is a media error. First try formatting a blank disk in that camera itself. If that doesnt work, try blowing out the disk slot with compressed air. I wouldnt use canned air like you can get at office supply places because if the can is tilted some of the propellant can come out and gunk up the inside of your gear. If dry compressed air doesnt work, have it serviced by an authorized Sony repair shop.
2answers
Top Electrolux Dishwashers Experts
Sudeep Chatterjee
Sudeep Chatterjee
Are you an Electrolux Dishwasher Expert? Answer questions, earn points and help others
