Washing Machines Logo
A
Anonymous Posted on Sep 29, 2014
Error code PAU, what it means
Getting error PAU when the unit turns on
RJ Keck
Level 2:
Novelist:
Scholar:
  • Expert 166 Answers
  • Posted on Jan 02, 2015
RJ Keck
Expert
Level 2:
Novelist:
Scholar:
Answers
166
Questions
0
Helped
49550
Points
274
The washer is stuck in "pause" mode. You can try pressing the Start/Cancel button to see if that clears it. If not, try unplugging the washer for about 10 minutes to force a reset.
If still no go, suspect problem with door latch/striker switch or failure of a cheap chinese control board. In fact, failure-prone chinese control boards are at the heart of virtually all premature failures of modern appliances. They usually only last just long enough to span the warranty period.
There should be an electrical schematic diagram attached to the back of the unit. You may be able to use that to identify the faulty part. Don't be surprised if the replacement board costs alot more than it's size and simplicity might indicate.
5 Related Answers
Anonymous
  • 878 Answers
  • Posted on Jan 13, 2008
SOURCE: F2 error code
Chia, this is not a good one, F2 is a keypad failure or interface mismatch. You can try a couple of things. 1. unplug the washer for a minute and see if the code returns. 2. Remove the consol to access the control board, three screws on the backside and the consol lifts up. On the right side you will see the main board. On the right side of the board, center harness will be the interface ribbon cable. Reseat it a couple of times. If this doesn't work, I believe you will have to replace the touchpad. Catriver.
Anonymous
  • 34 Answers
  • Posted on Aug 13, 2009
SOURCE: We are getting error code E3. What does this mean
Looks like you have either a stuck drum (does not spin) or an electrical fault that make the washer think the drum is not moving.
From a 2006 Technical Bulletin:
E3: Machine control is attempting to drive the motor but is not seeing any tach response. Visual Check shows motor is not moving. (Locked or Hall Sensor fault.)
Specifically, it could be:
1. Spin drum stuck – Verify that the spinner moves freely to eliminate this cause.
2. Hall Sensor (integral part of motor) fails or is loose – When the Hall Sensor fails or becomes dislodged, the control doesn't recognize that the motor is spinning and shuts down. The result will likely be an “E3” code in the worst case, or “SUdS” if it is only getting a partial rpm reading. Check wire harness connector(s) to motor.
Unless you are really overloading your machine you likely have an electrical fault, or a failure in the drive train--especially if the problem is intermittent. Probably time to call in a technician.
Anonymous
  • 43501 Answers
  • Posted on Mar 07, 2011
SOURCE: We are getting an error code of "PF" and can't
Here is a tips that I wrote that will help to explain why you get the PF Error Code
PF Error Code for Appliances
heatman101
0-=0
Anonymous
  • 2605 Answers
  • Posted on Jun 16, 2011
SOURCE: PAU error code comes on
Hello, welcome to FixYa
Based on the info you provided, specifically the E41 error, It sounds like the unit is detecting an unlocked door, loose wire, or the control itself is bad. (E41= Shorted or open. Defective door lock assembly.Around 1500Ohms. Defective control board.)
The PAU simply indicates the control thinks it has been paused...that may be just a side affect of the door lock assembly.
Here's how to check...
**Unplug the unit from the wall first...safety first**
Remove the door lock assembly and measure the resistance of the PTC. Should get a reading of around 1500ohms.
Attached here is a great tutorial for accessing the assembly for testing and replacing.
http://www.repairclinic.com/PartDetail/Door-Switch-Assembly/131763202/1531974
Let me know if you need further assistance going forward or if anything is not clear.
Thank's again for visiting FixYa today. Good luck.
Regards,
Macmarkus :)
Testimonial: "60 second unplug fixed the problem. Thank you!!!"
eMCee2
  • Posted on Jan 01, 2012
SOURCE: e17 error code
Got an E17 Error today on a Bosch 6450 Series washer (the user manual says Bosch Vision 300/500/DLX series). Here's what I did to fix the problem.
- Tilted the unit back, propped up the front with some 2x4 (lying flat; that's all the room I had).
- removed 3 screws (Torx 20 I think) under the front lip. Then slid the cover (below the washer opening) down. This revealed the pump to empty the washer, a manual door lock opening pull rod, and a drain line (?)
- Looking through some holes in the front panel I saw some water on the bottom of the washer... but I spent a lot of time with the pump cleaning it out first (some zipper pull got in there and made a lot of plastic shavings). - Ultimately I got my hand the bottom of the washer and soaked up the water that I could find. That's when I realized
- there is a micro switch mechanism at the bottom near the front. This must be the "AquaStop". The mechanism contains a bit of styrofoam that floats up on any little amount of water that collects under it and triggers the microswitch. So, I removed that unit, wiped the water up... put it all back together. No more E:17 error.
Still don't know how the water got there in the first place though.
Top Crosley Washing Machines Experts
jdthefixer
vince
Are you a Crosley Washing Machine Expert? Answer questions, earn points and help others
