Printer does not print when sent document from the computer. It queues the documents but does not engage the printer.
SOURCE: Computer Printing Problem
I'm assuming this is on a network printer.
1- try resetting the machine ( did not specify the model or make)
2- does it have the correct IP and gateway
3- try restting the PC and port
SOURCE: When printing documents from my PC documents always sent to queue
Go to control panel, printers. Set your defaults there. You probably have spooling enabled. Uncheck it and your print job will go to the printer, rather than to spooling. Spooling is like rolling the print job up on a spool until the whole thing is processed, then unwinding it to the printer.
SOURCE: Can't delete document from printer queue. Can't print anything.
I've had this problem several times, and the only solution is to restart your system. Once rebooted, the printer will continue printing your other documents
SOURCE: Hp laserJet 4250.
Replace the print driver on the computer. You can download the latest print driver from www.hp.com. Goto Software/Driver dwnld section.
