Parse error: syntax error, unexpected T_CONSTANT_ENCAPSED_STRING, expecting ')' in /var/www/proxy/.release/.core/proxy_s.php on line 367
Connect to the local server using Windows Authentication and specify
the
AdventureWorks database as the database in use. To connect using
SQL
Server Authentication, set values for the "UID" and "PWD"
attributes
in the $connectionInfo parameter. For example:
$connectionInfo =
array("UID" => $uid, "PWD" => $pwd));
$uid = "Administrator";
$pwd
= "Password1";
$connectionInfo = array("UID" => $uid, "PWD" =>
$pwd));
$pwd = "Password1";
$connectionInfo
= array("UID" => $uid, "PWD" => $pwd));
$serverName =
"(localhost)";
$connectionInfo = array( "Database"=>"dbase");
$conn
= sqlsrv_connect( $serverName, $connectionInfo);
if( $conn )
echo "Connection established.\n";
else
echo "Connection could not be established.\n";
die( print_r(
sqlsrv_errors(), true));
// Perform
operations with connection.
/* Close the connection. */
sqlsrv_close( $conn);
