Toshiba 1360 Black and White Copier Logo
A
Anonymous Posted on Jan 27, 2014
Error code c7
Fleshing, b ut doesn't work show C7
5 Related Answers
checkitright
CheckitRight
  • 1363 Answers
  • Posted on Oct 25, 2007
SOURCE: Toshiba 1360 C7 Error Code
TOSHIBA 1310 C7 Fusing unit warm-up error, defective thermistor, fusing lamp or thermofuse
The codes are good for several models.
Chuck Clark
  • 33 Answers
  • Posted on Oct 27, 2007
SOURCE: error c7
You can reset the C7 code, hold down 0&8 power machine up. Then push 87 & print, change the number to 0 with number keys press interupt key, then press 0&9 @ the same time to exit. This should clear the C7. Let me know if you need more help.
Anonymous
  • 51 Answers
  • Posted on Jan 17, 2008
SOURCE: C7 ERROR CODE
Your printer needs to be reseted.
Here's how to do it:
Switch on the machine, holding down 0 & 8 buttons, type in 89, press the green button, enter a 0, press green button again to accept the new value. switch off & then just switch back on as normal.
Hope it will work and solve your problem.
Anonymous
  • 148 Answers
  • Posted on Jun 21, 2008
SOURCE: C7 Eror Code
C7 Fusing unit not warming up properly. It can be the fuser is not in correctly, fuser connector not making good contact, defective thermistor, fusing lamp or thermofuse.
Hope that helps...
quennie732
  • 422 Answers
  • Posted on Jun 11, 2010
SOURCE: Toshiba 1360 C7 code. How expensive is it ti fix
With the unit off hold down clear/stop and 8, ad should apear push 89 start (display will read 03) then 0 start. tis should fix it. -Carl
Top Toshiba Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
Sudeep Chatterjee
Sudeep Chatterjee
Grand Canyon Tech
Grand Canyon Tech
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
