Lenovo G580 Laptop Logo
h
harrrrrd Posted on Dec 03, 2013
Touchpad problem i have problem with my touchpad, gestures arent working at all and sometimes touchpad does what he wants to, i mean he is not able to scan my moves properly, cursor jumps all over the screen, its really annoying
scotblok
Level 1:
Problem Solver:
  • Contributor 14 Answers
  • Posted on Dec 03, 2013
scotblok
Contributor
Level 1:
Problem Solver:
Answers
14
Questions
0
Helped
2085
Points
37
Have you made sure u have the very latest TouchPad drivers and Lenovo applications for your G580 installed?
If they are cleanly installed - theres a possibility that your touchpad has some minor physical damage.
Worth checking the software side first :)
Hope that helps
  • harrrrrd
    harrrrrd Dec 03, 2013
    yeah, i have installed latest driver, no change at all, i dont think its some kind of physical damage, because i am patient with my laptop, it started after installing win7 professional 64bit, it may be the problem, some conflict with win/driver
3 Related Answers
Anonymous
  • 73 Answers
  • Posted on May 26, 2009
SOURCE: problem related to touchpad not working properly
for you have used the machine for more than 1 year then your touch pad need to be replaced however if it has happened abruptly then reinstall the touch pad drivers
Anonymous
  • 366 Answers
  • Posted on Jul 01, 2010
SOURCE: Mouse Cursor Jumping while typing causing major typing errors
Reinstall the Mouse Drive rplease and it should work.
Please write abck if you still face problems.
Anonymous
  • Posted on Jun 07, 2012
SOURCE: cursor(pointer) cannot be moved by using touchpad but possibe wit
To stop the mouse jumping around whilst you are typing, have you tried configuring the touchpad? I had the same probelm but found configuring the touchpad to "disable whilst typing" then settng the "reactivation time" to one second.. This seemed to solve the problem in my case. I have a Medion Akoya. Good luck, Brian
What is multi gesture
do you mean multi-touch? It means that the device (touchpad or touch screen) can sense multiple fingers simultaneously.
gestures are specific patterns that perform tasks (like 2 finger scroll, pinch to zoom).
I am quite sure your trackpad supports multi-touch. If they arent enabled you can change the settings.For windows, go to - control panel> mouse>device settings tab> settings. (this might slightly change depending on the driver you have.)
Touchpad on panasonic cf-52
You're going to need the drivers for the gestures installed, you can find this on their website under support and drivers.
It's pretty much the driver for the touch pad, then you can enable gestures by opening the GUI on for the program and enabling "gestures"
Windows 8 Touchpad Gestures Uninstalled.
Hello My Friend, Don't Worry.
Just Install Driver booster software and install touchpad driver. It will install driver in your computer. Thanks..
My Asus Q500A-BHI5N01 touchpad won't let me scroll with the two finger gesture. The mouse works fine, but the touchpad isn't nearly as responsive as earlier. This is a new computer, less tha
Open the touchpad software, ASUS Smart Gesture, adjust sensitivity. Asua support : http://support.asus.com/Troubleshooting/detail.aspx?SLanguage=en&m=Q500A&p=3&s=450&os=&hashedid=n/a&no=1018
2helpful
My multi-gesture is disabled on my aspire one d257.. how do i enable it?
F7 key, or in tray(near clock) click on touchpad icon with right click and choise setting... or go to control panel - mouse settings...
3helpful
What is the multi gesture option available on my acer aspire timeline 4820tg and how do i switch it on or off . plz help me regarding this. regards ankit
The 4820TG's multi-gesture touchpad executes two-finger scrolling, pinch-to-zoom and rotate functions very well.The touchpad is a huge improvement from previous Acer touchpads. The touchpad is large and very responsive. The single touchpad button is comfortable to use and gentle to press. Multi-touch gestures and scrolling works well while surfing the Internet. Nevertheless, it is highly recommended to lower the sensitivity for "PalmCheck" in the Synaptics software to enable usage of the keyboard and touchpad at the same time. Enable/Disable and other touchpad settings can be made using Mouse Properties (from contril panel) and Synaptics Tab.
GoodLuck!
Dont forget to appreciate the solution if I could have been of any help!
CreativeTECH
4helpful
2answers
My touchpad works but not its multi gesture its emachines D730
most touchpad drivers will work on windows 7 but the program which control the functionality of the touchpad "Synaptics" or ALPS" pointing device may not be compatible in win7 this is an issue with most computer manufacturers but not their fault since win7 is a new operating system and possibly in the near future who knows when windows will come with a windows update to make touchpads work in windows having all it's functionality available.
try calling your computers maker and ask if they have work arounds for your touchpad some may have options to make all your touchpads functionality work but some may not try calling them and have them check it for you, they should know better since they are trained for the specifics of your system.^_^
1helpful
3answers
Mouse touchpad, keyboard, and usb drives will not work
One thing you can try (for the touchpad)
Acer have got a function key to turn it on and iff (i thought mine was broken for a year). Hold the function key, which is located bottom left of keyboard, and then press F7. It should be F7 anyway.
Hope that helps for your touchpad
Top Lenovo Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
Sudeep Chatterjee
Sudeep Chatterjee
Grand Canyon Tech
Grand Canyon Tech
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
