Electronics - Others Logo
A
Anonymous Posted on Sep 15, 2013
Set up mp3 player - Maxell Electronics - Others
I don't know how to put E-books and movies and stuff on my 2g mp3 player can anyone help me?
You can use media player to convert most sound files to MP3's, but if you are downloading MP3 files2_bing.gif you can copy straight in to your player's music folder and play the files. Does your player hook up to the computer as a "portable device" or as a removable drive? If it hooks up as a removable drive you are set to go with copy and paste. If it hooks up as portable device you need to check in the players settings and look for USB settings and see if you can set it for MSC mode. repost if need more info. How To Download MP3's To My Player.
Solve your MP3 Player Connection Problem.
Check out these tips for more help.
I would like to download audible books to my mp3 player. What format does Windows media player use to do this. I have an Eclipse 180BL 8GB
Ok lets look at your mp player. Name brand and model, what do you have? Some players do not have to have media player to put files onto your player. You can use media player to convert most sound files to MP3's, but if you are downloading MP3 files you can copy straight in to your player's music folder and play the files. Does your player hook up to the computer as a "portable device" or as a removable drive? If it hooks up as a removable drive you are set to go with copy and paste. If it hooks up as portable device you need to check in the players settings and look for USB settings and see if you can set it for MSC mode. repost if need more info. How To Download MP3's To My Player.
Solve your MP3 Player Connection Problem. Check out these tips for more help.
1helpful
Dosn`t want too start
What I would do is open your mp3 player through my computer and copy all your music, photos, and viideos onto your computer. Then I would go and download the firmwear from the manufacture and reflash your player. That will set it back to the factory settings.
I have a sansa mp3 , i am unable to down load my bible cd to my mp3 player,cd says it will work with mp3 player
I would need more info to help, but try this. Put your cd in your computer, using windows media player rip your music to a folder you can find, be sure to ck your settings in the Media player, for MP3 output, not wma. right Click on the top menu bar, chose > tools > options > Rip music tab. Set the output folder and output file type here. once done copy from that folder to your mp3 player be sure you have the room to store the files. My set has 62 cd's I rip a cd at a time and listen to one book at the time, save the main files on my computer and swap them on off my mp3 player as I listen.
Accidental mp3 player accidental overload
under the menu/settings/system/ they have reset settings as well as erase internal storage or external
Sansa c240 won't show what songs are on the player
Turn on the mp3
go to settings
go to system settings
then go to USB MODE
try first setting "AUTO DETETECT"
IF THAT DOES NOT WORK TRY MTP
AND THEN MSC
ONE OF THOSE SETTINGS WILL WORK..
WHAT WINDOS OPERATING SYS ARE YOU USING?
2helpful
CAN'T DOWNLOAD SONG ON MY GPX MW3847 MP3 PLAYER
First, you need to ensure that the switch on the side is set to OFF...
then if you have Windows Media Player 9 and (Windows 2000 and before ie Windows ME/98) ,
Second, Hit the M Button and Make sure that you have the player set to USB
but then if you have Windows Media Player 10, 11 (Windows XP, Vista)
Hit the M Button and Make sure that you have the player set to MTP
and if you have no Windows Media Player ...
copy your music mp3 files using windows explorer or my computer
3helpful
''Freeware'' COBY software to download pic's, video and music
To upload file to the COBY MP3 player, I went to setting, went to USB setting's, changed MTP mode to MSC mode then I was able to get access to folders with-in the mp3 player.
The_Tonester
Mp3
Your MP3 file might not have any content on the right channel. Try another Mp3 file. If the problem occurs on another file check the hardware:
Unplug the headphones from the mp3 player. Try another set of headphones. If the problem occurs with another set of headphones, it is a broken player. If using another set of headphones cures the problem, try your original headphones again. Plug your original headphones back in. If the problem comes back, buy a new set of headphones.
Innovage mp3
you should check the settings on the mp3 player. I remember that many mp3 players have a setting called play the first 10 seconds of every music. Anyway check the similar setting on your mp3. Goodluck!
Top Maxell Electronics - Others Experts
Sudeep Chatterjee
Sudeep Chatterjee
ADMIN Eric
ADMIN Eric
Are you a Maxell Electronics - Other Expert? Answer questions, earn points and help others
