Canon PIXMA MP190 All-In-One InkJet Printer Logo
Anonymous Posted on Nov 18, 2017
I can't print
I am using Mac OS X 10.5.6. Whenever I click print I get the message "Error Number : 1250 Document printing cannot be executed because the paper output tray is closed. Open the paper output tray. Printing will restart." I have loaded the paper correctly in the printer. I don't understand what I can do to fix this problem! Help!
Clive
Level 3:
  • Canon Master 882 Answers
  • Posted on Nov 18, 2017
Clive
Canon Master
Level 3:
Answers
882
Questions
30
Helped
219602
Points
3292
Hi Paul.
Try lightening settings from Windows Control Panel>Printers and Devices>right-click XEROX>settings.
My CMYK and mono printers are SAMSUNG, last one was HP.
The menu screenshot should hopefully be similar to Xerox.
As only the XEROX is doing this, I suspect your XEROX specific user settings in Windows are set too dark.
The signature was probably done on paper, which is fibrous when magnified.
When scanned, the slight shadows between the fibers are converted to random white and slightly off-white pixels.
To the human eye it appears white, but when darkened, the not pure white pixels are visible, creating noise.
Besides setting darkness to normal or light, you could also try setting ECO to on. If the xerox has economy printing.
5 Related Answers
Anonymous
  • Posted on Nov 05, 2007
SOURCE: wont print
The problem occurs when the paper tray is pushed down too far and 2 flimsy stop tangs on the backside of the tray hinge break off. The one on the left side contacts a microswitch, pushing it forward , signaling the printer tray is open. When the left tang breaks off, there is nothing to press the switch. You can try bending a paper clip in a fashion that hold the switch forward.
OR (the following will probably void your warranty)
Unplug the printer
Pull out the envelope tray on the bottom.
Set the printer on its back
Look just behind the bottom of the tray door from the underside
There are 2 wells on the underside. The front most wells are more square-shaped.
The 2 wells behind the are irregular-shaped. These 2 have the cover release tangs. Take a long, thin #1 flat blade screwdriver and push them outward toward the sides of the printer to release the 2 inside catches.
Next, push the screwdriver into the 2 rectangular release holes on the bottom sides of printer (beneath little arrows) to release the side tangs.
Next, release the rear tangs in similar slots in the back of the printer.
Gently lift up the cover. Lift up the electronic module on the left side.
The output tray wicroswitch is the black one on the bottom of the electronics module fix it in the upper position with either a small zip-tie or good electrical tape (the top one signals that the top cover is open to expose the ink cartridges, leave it alone).
Carefully reassemble the printer, hopefully it will work.
Remember to open the tray when you print as the preventing switch is no longer functional.
Good Luck.
A
Anonymous
  • Posted on Jul 13, 2008
SOURCE: printer door open message
Further to this, the sensors can give way. Try soldering or pushing the two connections together. If you need to test, you will have to put the lid back on but you can leave the sensor out of the rinter by draping between the cover and the frame of the putput tray (be careful not to pinch it. AAMOF I leave my sensor out as even though I've pinched it together it has a habit of coming undone.
Anonymous
  • Posted on Apr 02, 2010
SOURCE: error code while trying to print
Slap the printer with your right hand from the right side of the printer.This process always solves the problem. I did, it worked
Anonymous
  • 14 Answers
  • Posted on Mar 08, 2011
SOURCE: Document printing cannot be executed because the
there is a problem in the printer it is the carbon
Anonymous
  • 252 Answers
  • Posted on Mar 23, 2011
SOURCE: When ever I try to
Jilar,
Is the front tray down? That is the document output tray and it will detect an error if it's not down.
Grand Canyon Tech
Grand Canyon Tech
Sudeep Chatterjee
Sudeep Chatterjee
