Print item makes it to the queue but will not print and unable to clear the queue.
SOURCE: HP Deskjet 3845 print queue not clearing
Have you tried going to safe mode, turning off the printer and manually opening it at the control panel>printers... try and delete or cancel prinitng at these settings...
SOURCE: unable to clear printer queue
I had a related problem. Couldn't delete a job from the queue nohow. I wound up deleting various processes (CTRL ALT DEL PROCESSES tab) and it cleared it.
SOURCE: Print queue will not clear after printing
dear sir
this is a typical usb inkjet printer problem
just follow the steps
open notepad
and copy paste
net stop spooler
del %systemroot%\system32\spool\printers\*.shd
del %systemroot%\system32\spool\printers\*.spl
net start spooler
and save as delete.bat file on desktop
run this file and reboot the machine
and run this file again
now print queue will get cleared
thanks
SOURCE: I cancelled a print job from the Vista Printers
hi,
you need to delete the jobs and print the stuffs...
you need to give the following commands in the command promt which can be accessed from the start menu or by clicking "windows key+r"
net stop "print spooler"
to stop the print spooler
after you have stoped the print spooler
Browse to your windows\system32\spool\PRINTERS\ folder
You should see files there ending in .SPL and .SHD created around the time you tried to print – delete these files.
now try to print the stuffs..
if it clears the mess please give a vote....
