Minolta DiALTA Di250 All-In-One Laser Printer Logo
Anonymous Posted on Feb 03, 2013
C0500 error code
I got this code today and don't know how to reset it. Followed some instructions I found on the site for other models, but didn't work.
Adorjani Laszlo
Level 3:
  • Minolta Master 1,316 Answers
  • Posted on Feb 04, 2013
Adorjani Laszlo
Minolta Master
Level 3:
Answers
1316
Questions
Helped
469097
Points
2563
Step 1:
The error code fusing unit heater lamp malfunction.c0500 error code - 2_4_2013_7_43_37_pm.jpg
Step 2:
Select the trouble reset and exit.If the error code appire again remove the fusing unit and repair.
1 Related Answer
Anonymous
  • 7 Answers
  • Posted on Dec 28, 2008
SOURCE: error code C0500
C0500: Warming-up Failure C0510: Abnormally Low Fusing Temperature C0520: Abnormally High Fusing Temperature Relevant Electrical Parts Fusing Roller Heater Lamp H1 Fusing Roller Thermistor TH1 Fusing Roller Thermostat TS1 Fusing Roller Heater Lamp Fuse TF1 Side Cover Interlock Switch 2 S3 Power Supply Unit 1 PU1 Master Board PWB-A
Step Check Item Result Action 1 Does H1 turn ON after the malfunction is reset? YES Check TH1 for contamination or installation. 2 Is there continuity across CN3-1 and 2 on the Fusing Unit end with CN3 (2P) disconnected? NO Check H1, TS1, and TF1 for continuity. 3 Is there continuity across 1A and 1B, and across 2A and 2B, of S3 when S3 is turned ON? NO Change S3. 4 Is the resistance of TH1 (across CN5-2 and 3 on the Fusing Unit end) infinity? YES Change TH1. 5 Is Fuse F2 on PU1 conducting? YES Change PU1 or PWB-A. NO Change the fuse. Step Check Item Result Action 1 Is TH1 installed properly? NO Install TH1 correctly. 2 Is TH1 dirty? YES Clean or change TH1. 3 Is the circuit across CN5-2 and 3 on the Fusing Unit end closed when CN5 (4P) is disconnected? YES Change
Top Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
Sudeep Chatterjee
Sudeep Chatterjee
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
