Minolta DiALTA Di250 All-In-One Laser Printer Logo
Posted on Dec 28, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Error code C0500
What is meant by error code C0500 for dialta di250
Anonymous
Level 3:
Genius:
  • Master 2,120 Answers
  • Posted on Dec 28, 2008
Anonymous
Master
Level 3:
Genius:
Answers
2120
Questions
0
Helped
681533
Points
5011
Fuser Unit not heating up.
Anonymous
Level 1:
Problem Solver:
  • Contributor 7 Answers
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
7
Questions
Helped
4802
Points
13
C0500: Warming-up Failure C0510: Abnormally Low Fusing Temperature C0520: Abnormally High Fusing Temperature Relevant Electrical Parts Fusing Roller Heater Lamp H1 Fusing Roller Thermistor TH1 Fusing Roller Thermostat TS1 Fusing Roller Heater Lamp Fuse TF1 Side Cover Interlock Switch 2 S3 Power Supply Unit 1 PU1 Master Board PWB-A
Step Check Item Result Action 1 Does H1 turn ON after the malfunction is reset? YES Check TH1 for contamination or installation. 2 Is there continuity across CN3-1 and 2 on the Fusing Unit end with CN3 (2P) disconnected? NO Check H1, TS1, and TF1 for continuity. 3 Is there continuity across 1A and 1B, and across 2A and 2B, of S3 when S3 is turned ON? NO Change S3. 4 Is the resistance of TH1 (across CN5-2 and 3 on the Fusing Unit end) infinity? YES Change TH1. 5 Is Fuse F2 on PU1 conducting? YES Change PU1 or PWB-A. NO Change the fuse. Step Check Item Result Action 1 Is TH1 installed properly? NO Install TH1 correctly. 2 Is TH1 dirty? YES Clean or change TH1. 3 Is the circuit across CN5-2 and 3 on the Fusing Unit end closed when CN5 (4P) is disconnected? YES Change
3answers
Error Code C0500
Check the Fuser Unit - the part that heats up and melts the toner to the paper.
clean the contacts for the fuser lamp first.
Co500 trouble code
C0500
Warm-up failure
- The surface temperature of the Fusing Roller does not reach a given level even after the lapse of a given period of time during a warm-up cycle.
My konika minolta bizhub 162 is saying service call C0500 and then restarts what can i do
Verify the fusing unit components (heater lamp,thermistor) and the rear contact Switch located under rear cover when you closed the fusing unit right cover door.
How can i reset my konika minolta 162 to function well which is writing service call and a code C0500
C500 fusing unit malfunction.Look at a liitle holle on the right side on display.Press the microswitch and wait will apeire * and press 3 and press trouble reset.
Konica machine trouble service c0500 reset
On the right side of display located a display contrast key and a little hole.Under little hole is a reset switch,press the reset switch and wait to apeir * and press 3.
C0500 error code
Step 1:
The error code fusing unit heater lamp malfunction.2_4_2013_7_43_37_pm.jpg2_4_2013_7_44_01_pm.jpg
Step 2:
Select the trouble reset and exit.If the error code appire again remove the fusing unit and repair.
46helpful
3answers
IMAGISTICS 2620 Error code C0500
How to reset malfunction code C0500 of a imagistic
C0650: Faulty PC12 C0651: Faulty PC13
Relevant Electrical Parts Scanner Home Position Sensor 1 PC12 Scanner Home Position Sensor 2 PC13 Scanner Motor M5 Master Board PWB-A BCR Board BCR HGB Board HGB MFB Board UN2
MARCO
low fuser tem , must be rest or parts relaced
Top Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
Sudeep Chatterjee
Sudeep Chatterjee
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
